SOHC.co.uk Forums => CB750 => Topic started by: adespin on August 02, 2018, 06:50:56 PM
Title: Running On Two Cylinders
Post by: adespin on August 02, 2018, 06:50:56 PM
I recently rebuilt the carbs on the K1 including setting the float hights, but couldn't run the bike untill the exhaust fiasco with David Silver was sorted out. Now after fitting a new set from CMS which fitted great, i took it for a ride, ten minutes into the ride it started to misfire running on two cylinders, managed to get it back home which was not easy in hilly Wales. Touching the silencers revealed that it was only running on 1 & 2, while rebuilding the carbs i replaced the fuel pipes from carbs to petrol tap as the old pipes were crumbling at the tap ends and leaking. The new pipes i got off ebay which were 5mm bore thin walled. What i discovered was one pipe feeding cylinders 3 & 4 had kinked on the bend close to the tap stopping the flow.
  So i can't rely on this fuel pipe from ebay. where do you guys and gals  get your fuel line from, and would you use 5mm or 6mm.
Title: Re: Running On Two Cylinders
Post by: Johnwebley on August 02, 2018, 07:05:46 PM
I use 5mm smooth .available on Ebay. But not thin wall.sorry can't find link.
Is it nitrile. Try a search
Post by: adespin on August 02, 2018, 07:49:19 PM
Anybody got any links on ebay.
Post by: Nurse Julie on August 02, 2018, 08:02:21 PM
Trig will be in soon, I will get him to let you know where he gets his stock from.
Post by: RGP750 on August 02, 2018, 08:47:53 PM
This is what I used.
https://www.ebay.co.uk/itm/NEOPRENE-PETROL-OIL-FUEL-PIPE-HOSE-LINE-for-4MM-6MM-FITTINGS-0-5M-LENGTH/300884378774
Post by: Trigger on August 02, 2018, 08:51:42 PM
Link >>> https://www.ebay.co.uk/itm/Nitrile-Rubber-Smooth-Fuel-Tube-Petrol-Diesel-Oil-Line-Hose-Pipe-Tubing-NBR-1MTR/140693835989?hash=item20c20190d5%3Am%3AmMBu01U7HwzBmFVCcm3xAgg&var=440044001332&_sacat=0&_nkw=nitrile+fuel+hose&_from=R40&rt=nc&_trksid=m570.l1313
Post by: adespin on August 02, 2018, 11:32:37 PM
   Thanks All :)
