SOHC.co.uk Forums => CB750 => Topic started by: Arch stanton on August 31, 2018, 10:34:13 PM
Title: Filter bolts?
Post by: Arch stanton on August 31, 2018, 10:34:13 PM
Hello.
Cb750k/Cb750f1 oil filter bolts.
Do they differ in length?
Sean.
Title: Re: Filter bolts?
Post by: neat street on September 01, 2018, 09:51:44 AM
looking at the K1 drawing and F1 the part Nos are the same 15420300020
info from CMSNI
Post by: Arch stanton on September 01, 2018, 02:03:59 PM
Thank you.
I thought they would be the same.
It just something that came up. Becuse ive struck a small oroblem fitting a oil cooler.
Sean.
Post by: Bryanj on September 02, 2018, 12:37:56 AM
Oil cooler will normaly have an adaptor plate held on with a steel "nut" that the standard bolt screws into. F2 had a longer bolt with a finned adaptor plate( no cooler hoses) that was supposed to keep oil a bit cooler
Post by: ka-ja on September 02, 2018, 09:15:57 AM
There is a longer bolt that allows an oil cooler to be fitted as I have both adapter and bolt sat in my garage, but I can't remember which bike the bolt was an original fitment for, but maybe not a Honda.
Post by: Arch stanton on September 02, 2018, 09:23:18 AM
Hello Bryan.
I have a Serek oil cooler from a F1 i had yonks ago.
But i have lost the bolt adaptor that hold the sandwich plate in place. So i have had one made.
But when the filter bolt is tightened, the filter housing is 10mm of the plate. I cannot make the female thread any deeper,
But i can shorten the thread on the bolt.
This is why i asked about bolt lengths.
Sean.
Post by: Bryanj on September 02, 2018, 12:09:43 PM
Sounds like that might be an F2 bolt, all the other 4's are the same so if you can get one of those to measure it would confirm it.
Post by: SumpMagnet on September 03, 2018, 11:53:41 PM
I got an F2 bolt I can measure if that helps. It's all apart right now...so the bolt is in the parts pile
