SOHC.co.uk Forums => CB350/400 => Topic started by: billdn on September 10, 2018, 08:27:49 PM
Title: after market coils
Post by: billdn on September 10, 2018, 08:27:49 PM
i'm about to fit the coils to my rebuild but there is something amiss. the original parts listing shows the coils as discontinued so i ordered the after market coils (part no 30501-300-003P) some while ago, now is the time to fit them but there is a problem. the original brackets that fit the coils to the frame have a 5 mm tapped thread hole which the original coils fixed to via a screw. the after market coil will fit the gap in the bracket but the fixing hole is 6 mm  diameter with a 6 mm bolt which wont fit the original fixing bracket - i'm assuming I just drill out the old bracket and retap a thread, also the collar when offered up gives the appearance that there will be insufficient thread for the spring washer and bolt. Any ideas or am i barking up the wrong tree!
Title: Re: after market coils
Post by: Johnwebley on September 10, 2018, 09:07:52 PM
buy some 5mm bolts,cap head allen are good,as they can be worked on easily.
 the slight looseness shouldn't make a difference
Post by: billdn on September 11, 2018, 06:12:06 PM
Sounds less aggro than my plan!  thanks for the tip!
