SOHC.co.uk Forums => CB350/400 => Topic started by: Davelu88 on October 14, 2018, 06:11:26 PM
Title: Link size help
Post by: Davelu88 on October 14, 2018, 06:11:26 PM
HI all . need to get a new link for my 400 chain but am unsure what size to order the chain has 96 links without split link . many thanks
Title: Re: Link size help
Post by: hairygit on October 14, 2018, 06:24:21 PM
If it's running a standard size chain it should be a  530 (in old money 5/8ths X 3/8ths)
Post by: Davelu88 on October 14, 2018, 06:27:38 PM
Many thanks for that
Post by: Bryanj on October 14, 2018, 07:12:31 PM
Pproblem you have is whilst width and pitch are a "standard" different manufactureres can use different pin and bush sizes so you need the same make as the chain to be safe
Post by: Davelu88 on October 14, 2018, 08:26:25 PM
I Dont know make of chain, which is a pain :-\
Post by: Bryanj on October 15, 2018, 03:07:15 AM
There is usually some sort of mark on the side plate of the link from which you can determine the make. Did you fit it so you know where it came from?
Post by: Davelu88 on October 15, 2018, 01:49:34 PM
No it came with the bike but has clearly very little miles on it but it had a rivet link so when the engine came out and a rear wheel refurb  i ground off the rivet link . It does say EK50 HVO on the links but i cant find any info on this chain
Post by: Nurse Julie on October 15, 2018, 02:25:36 PM
http://setiawanteknik.com/wp-content/uploads/2016/06/EK-Roller-Chain.pdf
Post by: Davelu88 on October 15, 2018, 02:40:20 PM
Trust a Nurse to  help !!     Thanks Julie  ;D
