SOHC.co.uk Forums => CB350/400 => Topic started by: Athame57 on November 06, 2018, 09:53:34 AM
Title: Clocks and front brake calipers of CB400f2...gloss or satin?
Post by: Athame57 on November 06, 2018, 09:53:34 AM
I'm going to paint the clocks and the front brake calipers of my CB400F2...it's clear someone has done this before and not too well. They are gloss just now but I suspect it should be satin?
Title: Re: Clocks and front brake calipers of CB400f2...gloss or satin?
Post by: Laverda Dave on November 06, 2018, 10:24:22 AM
Yep, both should be satin black, PJI make a good black satin but it requires curing at 100c, OK for the brake caliper but I wouldn't use it on the clocks unless you have stripped them down.
Post by: mike the bike on November 06, 2018, 11:00:55 AM
Satin
Post by: Nurse Julie on November 06, 2018, 12:45:58 PM
Satin
Post by: SumpMagnet on November 06, 2018, 03:19:04 PM
I got to do the ones on my 750, and I am going satin. I will 'cure' it in the oven as I will be taking out the pistons and fitting new seals as a matter of course.
Post by: Athame57 on November 06, 2018, 03:26:45 PM
Is it ok to use normal paint on the caliper?
Post by: Nurse Julie on November 06, 2018, 03:38:13 PM
[attachimg=1]
Post by: Athame57 on November 06, 2018, 03:52:09 PM
 ;D Will get some!
Post by: SumpMagnet on November 06, 2018, 08:32:38 PM
That's the stuff I bought...the VHT stuff.
I wouldn;t use ordinary sporay paint as I have seen what brake fluid does to it....and this stuff says it's chemical resistant.
