SOHC.co.uk Forums => CB750 => Topic started by: Arch stanton on December 18, 2018, 12:47:31 PM
Title: Help required. Regarding 750k1 electrics.
Post by: Arch stanton on December 18, 2018, 12:47:31 PM
Hello folks.
I am building a 750k1 almost from scratch. So I have no points of reference to work from.
What I need is a photo of the electrical department ie, under
The lh side panel.
Also where does the green earth lead connect to the frame?
I'm using a new wiring harness, which has a red wire with a male connector. I suspect that is for a fuse. But where should the other end of the fuse connect?
Any help & advice will be greatly appreciated.
Regards.
Sean.
