SOHC.co.uk Forums => Project Board => Topic started by: Moorey on February 02, 2019, 11:08:54 PM
Title: CB350F Rusteration
Post by: Moorey on February 02, 2019, 11:08:54 PM
No full restoration as I think it would be a shame really as the bike loads of character. Just a good fettling and making reliable and use it through this summer and take a bit of the load off the 750 and my new hip in the early part of the year. Pics as it goes on in no particular order, just doing bits as I fancy with no plan whatsoever. Someone has been attacking parts of the frame and swingarm at some time in its life with a rattle can but I should be able to remove it and get back to original paint on the frame.
[attachimg=1]
[attachimg=2]
[attachimg=3]
Title: Re: CB350F Rusteration
Post by: gtmdriver on February 03, 2019, 03:52:29 PM
Exactly what I've done with mine.
(http://i41.photobucket.com/albums/e254/gtmdriver/DSC00001_zpsi28pnpgg.jpg) (http://s41.photobucket.com/user/gtmdriver/media/DSC00001_zpsi28pnpgg.jpg.html)
I've repainted the coloured panels, fitted a new exhaust and rear spring/dampers, reconditioned the forks, swinging arm, wheel bearings and brakes and fitted electronic ignition and an electronic regulator but the frame, engine and chromework is all untouched. I just want to ride it rather than restore it.
Post by: Nurse Julie on February 03, 2019, 07:10:56 PM
Both your bikes look lovely.
Post by: Moorey on February 03, 2019, 08:49:15 PM
A bit of rubbing and getting back to original paint and the frame is coming back to life.
[attachimg=1]
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
Post by: Moorey on February 03, 2019, 08:50:40 PM
[attachimg=1]
[attachimg=2]
Post by: Moorey on February 03, 2019, 08:54:37 PM
That all looks very nice.  Are the exhausts repo's from Silvers
Post by: matthewmosse on February 03, 2019, 11:43:18 PM
Very nice, that's how to make the most of a bike that's pretty reasonable. Looks lovely without spending an absolute fortune.
Post by: gtmdriver on February 04, 2019, 09:30:26 AM
[/quote]
They are repros but not from Silvers. 5 or 6 sets turned up on eBay a couple of years back for around £800 so I grabbed a set.
Post by: kevski on February 04, 2019, 10:08:20 AM
Don't blame you for not doing a restoration as it takes away the originality, my own has a wonderful patina that cannot be replicated, and parts that needed replacing done.
Post by: Moorey on February 04, 2019, 08:07:48 PM
Coils, horn, and ignition switch back on. Harness and connectors cleaned up. New brake pads come today so moved to the front and end up getting distracted with the bent headlight bracket which is throwing the indicator and reflector forward and stands out like a sore thumb when you look at it
[attachimg=1]
[attachimg=2]
[attachimg=3]
[attachimg=4]
Post by: Rob62 on February 04, 2019, 09:21:16 PM
Coming on nicely....
Post by: Moorey on February 05, 2019, 08:18:47 PM
Gave the headlight bracket a bit of a knock about, at least the indicators and reflector are square to the bike will keep an eye out for another. Its not a long job to swop. Got rid of the rust on the inside of the mudguard and went for the oily rag finish. New seat cover arrived today. Amazingly I have never done one before.
[attachimg=1]
[attachimg=2]
[attachimg=3]
Post by: Green1 on February 05, 2019, 08:27:25 PM
My kind of restoration.
The chrome looks good in the pics
Post by: Moorey on February 05, 2019, 08:34:01 PM
To be fair pics are always better than reality.
Post by: Green1 on February 05, 2019, 08:37:36 PM
I'm sure its fine looks like the chrome on my bikes it shows it has history behind it.
Post by: andy120t on February 07, 2019, 07:49:35 AM
Looks really nice. That is the sort of finish I like to see - so a bike you can use and not worry about getting wet rather than something that's over restored.
Post by: Moorey on February 07, 2019, 10:48:45 AM
Thanks all, one things for sure it will get used in the wet at some point.
Post by: Rozabikes Tim on February 07, 2019, 02:57:33 PM
Nice bike. Crich this year so we can all inspect it??
Post by: Moorey on February 07, 2019, 05:04:04 PM
Schools still out on that one yet.
Post by: Moorey on February 08, 2019, 03:48:13 PM
Front wheel back in and new Brembo brake pads. New seat cover on and electrics cleaned up and a little more of the frame done.
[attachimg=1]
[attachimg=2]
Post by: JamesH on February 08, 2019, 03:59:01 PM
Coming along very nicely. Like where you're going with this..:-)
Post by: Moorey on February 08, 2019, 04:17:13 PM
Thanks James, still undecided what to do with the exhausts though.  :)
Post by: Moorey on February 12, 2019, 10:57:33 PM
Just to add a bit of interest to the job the bike lift decided to break down when in a position that made it impossible to get at the ram and mechanism. All sorted once I managed to get to the ram now goes up and down like a good un again.  :)
Post by: Moorey on February 13, 2019, 08:54:14 PM
A bit more progress today. Sorted out the deformed and grey looking airbox with the use of a hot air gun.
[attachimg=1]
[attachimg=2]
Carbs back in and new cables. What a pain in the arse getting the carbs back in. A lot worse than doing the 750. Is there a easy way. Am I missing a trick somewhere.
[attachimg=3]
New internals in the petrol tap tank back on and seat with new cover. There are a couple of dings in the tank that I will try to remove when I can get to make something to try and press them out from the inside.
[attachimg=4]
Post by: Moorey on February 13, 2019, 09:19:26 PM
New plugs and caps. Whilst they were out checked the compression.
[attachimg=1]
[attachimg=2]
[attachimg=3]
[attachimg=4]
Plugs back in, swilled the tank out with diesel, put some petrol in the tank and away it went.  I have 1 float bowl leaking on the gasket. Bugger. I hoped I would get away with re using them. New ones now coming.  :) I obviously need more practice with them carbs anyway.
Post by: Nurse Julie on February 13, 2019, 10:09:29 PM
Great work.
Post by: kevski on February 14, 2019, 09:02:02 AM
I found the carbs relatively easy to put back on compared to my Z thou, mind you new rubbers were used both sides of the carbs.
Post by: Rob62 on February 14, 2019, 12:36:18 PM
Looks like its gonna be a little corker! 8)
Post by: mattsz on February 15, 2019, 07:05:03 PM
Mind if I ask, how are you cleaning and treating the frame and parts?  Mine is pretty filthy, but I don't want to just hose it down with water as some of the pieces and parts are removed (including the carbs), nor do I want to do a big degreasing job on the engine and lower/rear frame parts as I don't want oil and degreaser to soak into my dirt driveway.
I'd like to get it all clean, then degreased; maybe do something about the frame surface rust where the paint's off...
Post by: Moorey on February 15, 2019, 07:55:39 PM
It is all been cleaned whilst on the bench, greasy oily bits done with a cloth soaked in kerosene doing a small area at a time and then drying with a clean cloth. Someone in the past has been at the frame with a rattle can and I am removing that just with T cut and plenty of rubbing until I get back to the original paint. Its easy to tell when you get back to original. On non paint surfaces good old Solvol , and finish with a good wax polish. No secrets or magic formulas, basically elbow grease. Its surprising what you can get back just with a good old rub. The pinstripes are a little distressed on the 350 and I cant make my mind up whether to leave them or remove and apply new ones.
This is a spare tank I bought for the 750f that someone in their wisdom thought would look nice with a black stripe up it. So I rubbed it away.
Before.
[attachimg=1]
After
[attachimg=2]
[attachimg=3]
Post by: mattsz on February 16, 2019, 11:28:53 AM
Oh dear, that black stripe!  :o Well done on its removal...
No bench for me, the bike is still in one piece!  I do have lots of rags, though, so I'll just start at the top and work my way down...
Post by: Moorey on February 16, 2019, 01:04:26 PM
This mornings bit . Got the leaky float bowl off and the seal has broken, stuff just doesn't last anymore. Waiting foe new seals now.
[attachimg=1]
Time to start on the back end, out with the wheel, swingarm and off with the mudguard, started with a bit of  a clean down with a petrol, diesel mix which leaves a bit of a oily residue.
[attachimg=2]
[attachimg=3]
[attachimg=4]
Hopefully I will never need to refer to these.
[attachimg=5]
Now off to exercise my hip by walking to the pub.  ;)
Post by: K2-K6 on February 16, 2019, 02:41:40 PM
The domestic steam cleaning machines with single nozzle do a reasonably good job of getting oil based grime out of nooks and crannies.
Or wall paper stripper/steam thing.  Always nervous about sloshing flammable stuff around inside buildings.  :o
Just get a drip tray underneath to let it flush down.
Post by: Moorey on February 17, 2019, 05:33:27 PM
The drive chain was washed down and left to soak overnight in chainsaw chain oil I believe this could well be the original chain, now hanging up to drip dry. Is there any way of telling.  Removed the swingarm spindle and bush it doesn't look like it has ever had a grease gun on it, but both are in very good condition a bit of a confirmation the indicated mileage is correct.
[attachimg=1]
Attacked a couple of dings in the rear mudguard and they are far less noticeable now.
Before
[attachimg=2]
[attachimg=3]
After
[attachimg=4]
[attachimg=5]
Post by: taysidedragon on February 18, 2019, 08:23:10 AM
Nice work.  Do you use a car panel dolly on the mudguard dents?
Post by: Moorey on February 18, 2019, 08:49:35 AM
No just a pad of cloths on the bench to beat it on and used the rounded end of a old ratchet as a hammer. It doesn't need much its only thin. Gentle as you go.  ;D
Post by: kevski on February 18, 2019, 09:31:42 AM
You are cleaning away all the patina  ;), i don't think my 350f has ever been cleaned thoroughly in it's 47 years, though i do wipe down the bright work a couple of times a year, i must get round to it this spring .
Post by: Moorey on February 18, 2019, 10:32:14 AM
One mans patina is another mans muck.  ;D, What about all that patina you have wiped away on the brightwork   :( Don't worry it will get mucky again as it will be my daily rider for a good while. I just want it to look like a old bike that's had a bit of love shown.  :)
Post by: Moorey on February 21, 2019, 12:37:46 PM
Well the smoke got the better of me and I removed the exhausts. Number 3 is the smoker and I am hoping it is just the stem seal that's knackered. Whats my chances of it just been the valve stem seal. Am I right in thinking to change the lower o ring the valve guide has to come out. Iv'e opened it up and it looks great inside, very clean a bit more of a indicator the 4000mls is genuine. I am going to order just one new valve seal to see if it cures it. I am doing it without removing the head. More as a exercise to see if I can. If it doesn't work and cure it I will just have to delve in a bit deeper.
The last pic is the seal and valve springs removed with the engine still in the bike with the head and carbs still on.
I will have to give some thought to putting it back together, but I have until the new seal comes.  ;D
[attachimg=1]
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
Post by: Rob62 on February 21, 2019, 01:19:16 PM
looks nice and clean inside that rocker cover...  :)
Post by: Moorey on February 21, 2019, 01:24:32 PM
That's just how it came off.  :)
Post by: Bryanj on February 21, 2019, 03:04:57 PM
In too many years to think about i never changed a valve guide O ring except when replacing guides.
Post by: Moorey on February 21, 2019, 03:53:23 PM
Good to know Bryan.
Post by: andy120t on February 21, 2019, 04:16:31 PM
What are the five 'c's on the crankcase for?
Post by: Bryanj on February 21, 2019, 05:42:51 PM
Size codes for main bearings
Post by: andy120t on February 21, 2019, 06:38:39 PM
Oh  - thanks! I haven't seen those on my 650, but will have a look in the daylight to see if they are there too.
Post by: Andych on February 22, 2019, 01:50:47 AM
You see plenty of cars have valve seals replaced with the head or heads still on. They basically use a leak down tester to pressurise the combustion chamber and they use a fulcrum to compress the valve springs so they can slip in the collets... worth a try... worst that can happen is the valve wont stay up.. then you will need to drop the head off..
Looks to be in really good condition inside though..
Post by: kevski on February 22, 2019, 06:59:59 AM
Thread a length of rope into the cylinder bore then raise the piston to compress it against the valve bottom, do the job, lower piston, pull rope out, don't forget to leave enough rope hanging out of spark plug hole to retrieve the rope though.
Post by: Moorey on February 22, 2019, 08:54:00 AM
Its the rope method I have used. Getting the springs and collets off is easy, just put a socket on top and give it a tap and they jump out, getting them back in will be a bit more awkward.  :)
Post by: kevski on February 22, 2019, 09:12:20 AM
I thought the early ones did not have stem seals on the exhaust side, i have not been into mine so unable to verify.
Post by: Moorey on February 22, 2019, 02:09:09 PM
Mine has and I would say its top end has never been opened up before. I have now got a method of getting the collets back in.
Post by: Moorey on February 23, 2019, 10:17:13 AM
I thought the early ones did not have stem seals on the exhaust side, i have not been into mnine so unable to verify.
The parts book lists 8 for the F. Unless there is some confusion as the first engine number listed is 1068969.
It does say at the beginning of the book.
If there is a production change to a part, the frame or engine number to which this part become effected will be indicated in the " Serial No " column. However, in the case the part is used from the initial serial number, its applicable serial number is not shown.
I read that as it should have them, But could well be wrong . Hopefully someone more au fait with the Honda parts system will enlighten us.
Post by: royhall on February 23, 2019, 10:45:16 AM
Moorey. This is what I found whilst rebuilding my 350F. There's no real definitive answer on what is correct here, this was the comment a while back:
Some engines (mine included) had stem seals on the exhaust side and some had unsealed guides that are machined to a point to shed the excess oil. According to some on the internet the excessive wear is due to the stem seals on this engine and the lack of oil on the valve stems, and they should have the other type. Many others disagree and say to fit the 400 type with the seal (which as we know should be designed to leak slightly). I even checked the ones on Yamiya's site for the 400 and if you buy the full set they all have seals, if you buy the exhaust guides separately they don't have seals? All the guides on CMS for the 350 are without seals except for the French bikes. This is all a bit weird.I rang CMS with my engine number and they say the non sealed version so that is what I have gone with (even though seals were fitted in my engine). On top of that there are 4 different versions of unsealed guides so I went with the latest version. Just hope it's the right decision as I have fitted them now.
Post by: Moorey on February 23, 2019, 11:50:54 AM
My guides a machined to accept stem seals, so when the new one comes we shall see if it cures it.
I guess you pays your money and make your choice then.  ;)
I had read your smokey thread and the one on the US forum and then when I saw this bike was a smoker I just thought "Bollocks." We shall see though.
Post by: Moorey on February 23, 2019, 02:14:35 PM
The new one came just after my last post  the engine is up and running again now and it looks quite promising. I need to get it registered now and take it for a decent run to burn of all the old crap in the pipes. Quite happy with what I see now out of the headers.  :D
Post by: royhall on February 23, 2019, 02:38:29 PM
We need to know? How did you get the collets back on. Sounds promising on the smoke front though.
Post by: Moorey on February 23, 2019, 03:07:45 PM
Quite easy really I used the end off my spring compressor and used a length of timber between that and the frame to compress the springs. A blob of grease on my finger to hold the split collet and just wiped them onto the valve stem, released the spring and Bobs yer uncle.
Post by: Moorey on February 25, 2019, 03:35:58 PM
Booked it in for Mot in the morning.  :) Then send the paperwork off to get it registered.
Post by: Moorey on February 26, 2019, 01:50:28 PM
Passed its Mot, front brakes must be terrible to fail because these are shite. hopefully they will get better when the bed in. I had my first ride on it and it goes like a gud un, just doesn't stop like one. I don't like the exhausts they look too low so I will raise the back end of them by a good couple of inches either by bending or cutting and welding  as they don't need to clear the wheel spindle with the swing arm having open ends.
Just need a V5 and plate now. :)
[attachimg=1]
Post by: Nurse Julie on February 26, 2019, 01:51:49 PM
Brilliant.
Post by: JamesH on February 26, 2019, 02:47:13 PM
Great work well done..
Post by: Moorey on February 26, 2019, 04:22:42 PM
Another back on the road James thanks. Total spend not including purchase price and registration £324.
Post by: royhall on February 26, 2019, 04:41:05 PM
Nice one mate. The front brake will bed in a bit with use but will still be shite. ;D
Post by: kevski on February 26, 2019, 08:55:54 PM
Nice to see another 350f on the road and well done, the 350f along with the 500k3 are the best of the bunch, just my own view, it's a shame i have got to sell mine.
Post by: Laverda Dave on February 26, 2019, 11:02:43 PM
Lovely job, well done 👍
Post by: Rob62 on February 27, 2019, 10:46:23 PM
Great job! Bring on classic bike night at Squires
Post by: Moorey on March 12, 2019, 03:09:02 PM
As I was in the garage this morning measuring decals. I decided to alter the exhaust pipes. I've never liked the look of them thinking they run too low, below the rear wheel spindle.
[attachimg=1]
So I put the disc cutter through them and pulled them into what I thought a better looking line. Actually a 3inch rise at the end of the silencer. Then rewelded the 6mm gap I had made in pulling them up and cut down the huge mounting bracket.
[attachimg=2]
The end result I am far happier with and can live with. Still awaiting the V5.
[attachimg=3]
Post by: Nurse Julie on March 12, 2019, 03:59:09 PM
Those silencers look very good at that angle......a huge improvement.
Post by: Moorey on March 12, 2019, 06:46:15 PM
I am glad you agree as I didn't really want to get rid of them as they are Hookers, which were very big in drag racing in the 70s.
Post by: Rozabikes Tim on March 12, 2019, 07:28:53 PM
Gives it a bit more attitude well done.
Post by: SteveD CB500K0 on March 12, 2019, 08:04:22 PM
Hookers in drag.
OK
Post by: Moorey on March 12, 2019, 08:07:16 PM
Hookers in drag.
OK
Everybody should have a hobby.  :D
Post by: Moorey on March 12, 2019, 08:15:12 PM
Just come across these. https://www.ebay.co.uk/itm/Hooker-27125-Chrome-Tuned-Motorcycle-Exhaust-System-Header-Honda-CB350F/264206546359?epid=1650715532&hash=item3d83eff5b7:g:GikAAOSwDXxcbcT3
Post by: Rob62 on March 12, 2019, 08:25:42 PM
Looking good! Are they plated or stainless?
Post by: Moorey on March 12, 2019, 09:44:33 PM
Plated Rob it would have been nice if they were stainless.
Post by: Moorey on March 16, 2019, 10:41:31 AM
V5 arrived today so I can now send for a number plate.   :D :D :D
Post by: Rob62 on March 16, 2019, 05:44:42 PM
Shame the weather is so crap at the mo....you could have been out this weekend. What plate are you going for? Pressed aluminium black & white or a yellow one, there is a bike shop in pontefract that do a yellow aluminim plate while you wait, they are quite retro. I bought one to get me going whilst I waited for a pressed one to be made up and delivered...
Post by: Moorey on March 16, 2019, 07:04:21 PM
8x7 black and silver and should be here by Weds. It might have stopped raining by then.
Post by: Moorey on March 21, 2019, 09:29:52 PM
First ride out on it today, I did just over 20mls. Low revs lots of poor running and misfires. It ticks over lovely. Once above 5000rpm it runs lovely and goes great. It seemed fine on the bench but riding is a different kettle of fish. Plugs 1 and 2 were not bad 3 and 4 very sooty. Carbs are now off and will go through the ultra sonic cleaner.
Post by: Nurse Julie on March 21, 2019, 09:42:29 PM
Sounds good, well done. As you have said, it doesn't matter how well a bike runs on the ramp, nothing compares to getting it out for a ride to see what fettling is needed.
Post by: Moorey on March 21, 2019, 09:53:16 PM
Do you know the size of the O rings on the connecting pipes between the carbs Julie. Or anyone else for that matter. :)
Post by: Nurse Julie on March 21, 2019, 10:26:21 PM
I have no idea Chris, I always buy them as part of a kit. You could measure the ones you have or ask Gerben.
 gerbenhilly@hotmail.com
Post by: Moorey on March 22, 2019, 08:50:46 PM
I've measured them up 6mm ID x 2mm CS. You get 2 with each carb set, but need 12 in total if replacing them all.
Post by: Nurse Julie on March 22, 2019, 09:14:40 PM
I can send you 12 of them Chris. PM me your address and i will get them in the post.
Post by: Moorey on March 22, 2019, 09:34:15 PM
Just ordered some before I put the post on, but the offer is appreciated thanks Julie.
Post by: Nurse Julie on March 22, 2019, 09:42:27 PM
Trigger has been in the outside workshop for ½ hour, with a torch to find a bag of them for you. He has to use a torch as there are so many lights in the workshop, he can't afford to put them on just to look for some bits of rubber. He says that's the last bloody time he offers to help you.........only joking, no probs Chris, just glad you got sorted.
Post by: Moorey on March 22, 2019, 09:56:04 PM
I don't blame him I'd tell me to knackers as well in the future.  ;)
Post by: Moorey on March 28, 2019, 04:21:57 PM
Cleaned the carbs in the ultra sonic bath fit new carb kits and bench synced the carbs whilst the carbs were cooking I put a new valve stem seal on the inlet side. It really is a piece of piss to do using the rope method. Put the carbs back on the bike and had a ride to Sherburn in Elmet today a 50mls round trip. Much much improved, still the odd misfire now and then which feels more electrical than fuel or maybe me just not revving it enough and been lazy with the gears.  I am still on the original points and condensers which were on the bike when I got it. I let the old girl get a bit of wind up her nostrils and saw 90 on the clock before I ran out of road so its not doing too bad. I would happily set off anywhere on it now.
When I put the carbs back on every carb overflowed and no amount of tapping on the bowls would stop them until I turned the fuel off added a bit of 2stroke oil to the tank and started the bike with the fuel turned off then after a minute or so turned on the fuel and run the engine until it got warmed through and they have been fine since.
Ps I think the exhaust looks a lot better now , I might lift it at the back end a little more yet as its not hard to do.
[attachimg=1]
Post by: Nurse Julie on March 28, 2019, 06:04:55 PM
For what its worth, i think the exhaust looks just spot on where you have it now Chris.
Post by: Moorey on March 28, 2019, 06:57:42 PM
Input is always welcome.  :) Anyone else care to pitch in.
Post by: K2-K6 on March 28, 2019, 07:30:06 PM
I thought the same before Julie said it,  they look pretty good just there.  If raised too much they get a bit too "Dunstall" I think.
I think the bike is an unusual blend of design,  it looks very classic with fork shrouds, overall colour and graphics etc,  but at the time of issue so advanced to have a four cylinder of that capacity.
Looking back at old bike magazines,  British and other manufacturers were always proposing production four cylinder engines. Honda just went ahead and built it almost as an aside to other bikes.
I do think the original four pipes on the 350 are one of the best looking of all those from that era though. Surprises me that they are not a more numerous model bike though. I'd choose one over the contemporary twins without hesitation.
Very nice bike.
Post by: Rob62 on March 28, 2019, 07:41:33 PM
Pipes look great just as they are now...whole bike looks good  8)
Post by: Moorey on March 28, 2019, 08:12:53 PM
Have you been over this evening Rob.
Post by: Rob62 on March 28, 2019, 10:39:11 PM
Yes Chris, i went over straight from work... got there about 5 ish, stayed an hour or so. Not a bad turnout, a smattering of classic japs and brits, will be better once the spring is fully underway.... still a bit chilly once the sun goes down.
