SOHC.co.uk Forums => CB500/550 => Topic started by: Davelu88 on February 03, 2019, 05:47:50 PM
Title: 550K1 fork oil
Post by: Davelu88 on February 03, 2019, 05:47:50 PM
Hi all, anyone know how much fork oil should be in a 550K1 and what oil to use , searching brings up varying opinions.
Title: Re: 550K1 fork oil
Post by: Johnwebley on February 03, 2019, 06:06:01 PM
Assuming it's the same as the 500.
Try 160cc  atf oil
Post by: Davelu88 on February 03, 2019, 06:08:34 PM
Cheers John
Post by: Nurse Julie on February 03, 2019, 06:09:34 PM
[attachimg=1]
Or ATF
Post by: Trigger on February 03, 2019, 06:11:12 PM
Sorry to correct you John, it is 164.997 cc  :o and that is on a full strip and clean. If just a drain from the side bolt then totally different  ;D ;D
Post by: Davelu88 on February 03, 2019, 06:14:54 PM
Just a drain  & replace Graham , so what would that be. cheers
Post by: Trigger on February 03, 2019, 06:39:32 PM
It is very hard to get it correct with a drain. You can be out by 10cc on each fork but, the book says 135 to 145cc  ;)
Post by: deltarider on February 03, 2019, 06:58:00 PM
My CB500K2 (ED) has the same legs. I personally have best results with 140cc 7,5 weight.
Post by: Davelu88 on February 03, 2019, 07:48:21 PM
Cheers  ;D
