SOHC.co.uk Forums => CB500/550 => Topic started by: Davelu88 on February 27, 2019, 08:06:59 PM
Title: tank cap pivot pin
Post by: Davelu88 on February 27, 2019, 08:06:59 PM
Hi all , does anyone know where you can get the pivot pins with the circlips  for the cap and lock , i think one is longer than the other if i remember right.
Thanks in advance, Dave
Title: Re: tank cap pivot pin
Post by: Nurse Julie on February 27, 2019, 08:48:49 PM
Dave. I will get Graham to have a rummage tomorrow as I'm sure he has some. Don't buy anything until I get back to you.
Post by: Davelu88 on February 27, 2019, 09:01:57 PM
Post by: Nurse Julie on February 28, 2019, 01:15:41 PM
Dave, Trig hasn't got any. What I saw in a box has nothing to do with tank caps at all ::) ::) Sorry.
Post by: Davelu88 on February 28, 2019, 03:47:36 PM
No worries Julie  ,  thanks for looking & Silvers dont sell circlip pins on their own. :-\
Post by: Davelu88 on February 28, 2019, 04:11:19 PM
So please dont say you have to tap a normal pivot pin with a hammer to squish the end
Post by: Bryanj on February 28, 2019, 04:27:18 PM
Thats the way im affraid. I have used stainless set screws with acorn nut and locktite in the past.
Post by: Seabeowner on February 28, 2019, 04:56:09 PM
Hondaman in the US sells a screw and nut for this or get your own from this link.
http://sohc4shop.com/catalog/product_info.php?manufacturers_id=12&products_id=38&osCsid=413e0c7837c5700e425cd1e5100ca4b6
Post by: Davelu88 on February 28, 2019, 05:03:51 PM
That's what I want , cheers for that
Post by: Davelu88 on February 28, 2019, 10:27:51 PM
Yea they do look better but cant find them anywhere over here & im not paying that much from the USA , they are called suspension pins ,if anyone can find the right length ones over here that would be a bonus.
Post by: Trigger on February 28, 2019, 11:49:37 PM
3mm dia x 30mm under the head to the clip
3mm dia x 25mm under the head to the clip
3mm dia x 23mm under the head to the clip
This is a set that i am just about to fit, if i can find the clips  ???
Post by: Arch stanton on March 13, 2019, 01:22:00 PM
I have just used one of these pins on my genuine Honda fuel cap.
It worked fine on my 750k1.
Post by: Davelu88 on March 13, 2019, 03:11:53 PM
Thanks for that , I will order 1  ;D ;D
