SOHC.co.uk Forums => Anorak's Corner => Topic started by: CornerstoneCB on March 30, 2019, 06:37:45 AM
Title: CB750 1978f fried electrics
Post by: CornerstoneCB on March 30, 2019, 06:37:45 AM
Hi there,
Can anyone help? I made the rookie mistake of jump starting my 1978 F1 from a running car! Now when i turn the ignition key there is no lights on or power anywhere. I only just bought this bike and it ran fine before this.
Can anyone tell me where to start? I read it may be the main fuse? Where is it located?
Title: Re: CB750 1978f fried electrics
Post by: kevski on March 30, 2019, 06:50:59 AM
Either under the seat or behind one of the side panels.
Post by: CornerstoneCB on March 30, 2019, 07:15:36 AM
Thanks kevski.
So i looked behind the side panel and there is a bank of five fuses in a box. Some fuses are missing but it started ok before the jump start. Is there one particular fuse to look for or is it likely that everything is fried?
Post by: Bryanj on March 30, 2019, 08:11:27 AM
Fuses should be labeled main head and tail. The battery could be totally goosed, are you saying there is nothing when connected to a slave battery?
Post by: CornerstoneCB on March 30, 2019, 09:16:48 AM
Hi beyanj,
Originally there was power. I (stupidly) couldnt wait for a new battery to arrive! So i connected the +\_ to my car.
Now i have put new battery in and there is nothing. The ‘dash’ lights dont come on when i turn the ignition. Cant even jump start it.
Post by: Bryanj on March 30, 2019, 09:24:53 AM
Just connecting the car battery, even with engine running should not "fry" anything. It is more likely that something has come disconnected or missed. Almost impossible to do distance diagnosis on electrical problems i am afraid
Post by: Spitfire on March 30, 2019, 09:29:48 AM
I did have a problem with the fuse holder on my F1, stopped at the daughters house turned off the bike and when I went to go home it was dead, turned out to be corroded wires on the back of the fuse box, the front looked great but the back was shot. Same replaced and away we went.
Post by: CornerstoneCB on March 30, 2019, 09:35:45 AM
Thanks all!
