SOHC.co.uk Forums => CB750 => Topic started by: Andrew-S on April 05, 2019, 03:52:14 PM
Title: Removing Tank Mouldings
Post by: Andrew-S on April 05, 2019, 03:52:14 PM
Hi Folks,
I'm stripping down my K1's tank to send to Menno, but can't see any easy way to remove the bottom tank mouldings without damaging the tangs or the moulding, does it just slide out - the profile suggests it doesn't?
Grateful for advice, thanks
Andrew
Title: Re: Removing Tank Mouldings
Post by: Nurse Julie on April 05, 2019, 04:07:37 PM
You have to bend the tangs back to remove the trim but, they are prone to breaking if they are rusty.
Post by: Andrew-S on April 05, 2019, 04:15:54 PM
Thanks Julie,
Best be careful then, even though there's very little surface rust - at least the tank badges came off easily enough....
Andrew
