SOHC.co.uk Forums => CB500/550 => Topic started by: Erny on April 28, 2019, 07:51:07 PM
Title: Speedo gear lubrication - what to use?
Post by: Erny on April 28, 2019, 07:51:07 PM
Hand on my speedo gauge is shaking in some speeds, wants to clean and then re-lubricate speedo gear on the front wheel.
But wondering what lubricant shall I use? Thinking on some grease that is verz soft anf does not turn into liquid...
Any recommendations?
Note: the same I want to do on my CB750K K7
Title: Re: Speedo gear lubrication - what to use?
Post by: deltarider on April 28, 2019, 09:29:57 PM
Lithium grease
Post by: K2-K6 on April 28, 2019, 09:38:28 PM
Same as deltarider, lithium general purpose grease as used in car wheel bearings.
Post by: Moorey on April 28, 2019, 09:48:01 PM
If it is only doing it at some speeds are you sure it's not the cable.
Post by: Green1 on April 29, 2019, 12:17:10 AM
As above a naff cable can cause the clocks to do funny things.
Any damage or slight resistance swap it for a new one.
Post by: Erny on May 12, 2019, 04:13:11 PM
Lubrication done, shaking stayed... so next is cable to swap. Will order cable next time I make bigger order to DSS or CMS
Thanks!
Post by: Johnwebley on May 12, 2019, 07:31:03 PM
Thanks!
Wemoto do a nice range in cables.
I had to replace my tacho cable. And one of theirs fitted well .And looked well made.
