SOHC.co.uk Forums => CB350/400 => Topic started by: watty51 on May 05, 2019, 03:24:36 PM
Title: Fuel level in bowls
Post by: watty51 on May 05, 2019, 03:24:36 PM
Just set the floats to 21mm as per cylmer manual (Cb350f). Checked level in each bowl, all exactly the same height (see photo) ....Still seems  a bit low,
each level is about 10mm from the top of the bowl. Would that be about the right fuel level
Title: Re: Fuel level in bowls
Post by: sye on May 05, 2019, 04:04:47 PM
When the floats are in the bowl the level will rise, so all is good.
Post by: watty51 on May 05, 2019, 04:08:19 PM
Never thought of that. Many thanks for the quick reply
