SOHC.co.uk Forums => CB500/550 => Topic started by: paulbaker1954 on May 12, 2019, 07:24:49 AM
Title: Head Gasket
Post by: paulbaker1954 on May 12, 2019, 07:24:49 AM
Hi
I need to change my head gasket and can either buy the OEM one from DS OR I could get the aftermarket set from DS which gives me a complete engine set for same price
And advice on way to go our an alternative source of aftermarket stuff that works
Reason I ask as in an earlier post Trigger suggested that aftermarket ones are no good cos they are thinner and the o rings won’t seal which is the problem I have with an oil weep that is deffo coming from the head gasket level.
Strange as on an earlier build i used an aftermarket set and had no issues
Title: Re: Head Gasket
Post by: Trigger on May 12, 2019, 07:46:26 AM
No, i said most aftermarket ones are thicker than oem but, not all  ;)
Post by: paulbaker1954 on May 12, 2019, 08:07:19 AM
Apologies for misquote
Any recommendations on aftermarket?
Post by: Trigger on May 12, 2019, 08:17:11 AM
OEM, Vesrah, NP, NE with new pucks and measure up all the o rings  ;)
Post by: paulbaker1954 on May 12, 2019, 08:27:20 AM
Sorry but what are pucks
Post by: Bryanj on May 12, 2019, 10:27:59 AM
Yank word for the rubber pontefract cakes that cover the holes neede to get at head bolts between head and valve cover.
Post by: paulbaker1954 on May 12, 2019, 01:31:36 PM
Aha that’s like trunk and hood etc, two nations divided by a common language LOL
Post by: paulbaker1954 on May 13, 2019, 10:06:26 AM
Thanks Trig, ordered up an NE set from DS. Got head off yesterday and found I had used wrong  O rings on last rebuild looks like they were actually below the level of the head gasket !!
Moral measure twice cut once as they say or more haste less speed.
Next issue is 2 of the threads on the carb float bowls have stripped as I have had the damn things apart that many times. Luckily my local machiner can helicoil them
Post by: Seabeowner on May 13, 2019, 12:24:06 PM
I've had two CB500 gasket sets and two 550s. The 500 sets have contained the pucks, the 550s did not include them.
