SOHC.co.uk Forums => CB350/400 => Topic started by: Windycorner on May 16, 2019, 03:29:15 PM
Title: clutch help
Post by: Windycorner on May 16, 2019, 03:29:15 PM
Hi,
Looking at the clutch on my 400 today, theirs the usual play between the gear and basket which I am not bothered about,
but what worries me is the basket has scoring/grinding marks near the rivets on the inside, there not deep only just detectable by finger nail, should I be worried, has someone opened it. I've tapped the rivets and their not moving. hopefully the photos show it.
Title: Re: clutch help
Post by: Nurse Julie on May 16, 2019, 03:32:59 PM
Interesting. They are not rotational marks 🤔
Post by: paul G on May 16, 2019, 03:39:47 PM
Somebody been at it with a file !
Post by: mike the bike on May 16, 2019, 05:25:07 PM
Those rivets look like they've only got a flange on the one side and are a loose fit.  It's been buggered about with.
Post by: billywingnut on May 16, 2019, 06:13:16 PM
Looks like it's been done by PO 'working' on it. I had the problem with play in the gear which was causing 'slap' similar to a slack chain. I bought a s/h one off ebay with very little play which cured the problem
Post by: Windycorner on May 16, 2019, 07:25:04 PM
Has someone got a picture of the inside of the clutch outer, so I can see what the rivets should look like.
Post by: Trigger on May 16, 2019, 08:37:55 PM
Looks standard to me
[attachimg=1]
[attachimg=2]
Post by: Windycorner on May 17, 2019, 11:02:01 AM
Thanks for the pictures Graham and for all the comments, I think the rivets look the same flush with the surface, so I will clean and put it back in.
Cheers Neil
Post by: ka-ja on May 17, 2019, 07:19:03 PM
Could the "file" marks be someone's attempt to clean up the slots the clutch plates engage with?
