SOHC.co.uk Forums => CB750 => Topic started by: marka-cb750 on May 21, 2019, 09:15:50 AM
Title: UPPER HOLDER / INSTRUMENT PANEL
Post by: marka-cb750 on May 21, 2019, 09:15:50 AM
Hi there,
I have a 1977 Honda cb750f with the triangular style upper holder / instrument panel. I wish to change it for a cb750k6 style instrument panel - part number...53133374670.
Are the mounts right on the k6 upper holder to fit my top yoke on my f1?
Many thanks all
Title: Re: UPPER HOLDER / INSTRUMENT PANEL
Post by: hairygit on May 21, 2019, 09:53:00 AM
If you are referring to just the "idiot lights" (oil press, high beam neutral etc) then yes it should physically fit. That said, routing the wiring may be tricky, and the indicator light will cause some head scratching. The F has seperate lights for left and right, the K6 has only one for both sides.
Post by: davefirestorm on May 26, 2019, 02:55:57 PM
Another question regarding 750F speedo/tacho,chrome base on one of my clocks is dented can a chrome base from a K6 be used instead?
