SOHC.co.uk Forums => CB750 => Topic started by: Phil Ward (RIP) on June 07, 2019, 09:12:45 PM
Title: Desperately Seeking - CB750K Swing Arm Tube
Post by: Phil Ward (RIP) on June 07, 2019, 09:12:45 PM
Has anyone got a servicable centre tube out of the swing arm pivot for a 750K6 that they are willing to sell me? The project K6 I'm working on has it missing. Part number 52141390000
Title: Re: Desperately Seeking - CB750K Swing Arm Tube
Post by: Bryanj on June 07, 2019, 11:32:11 PM
Fairly certain you can use the earlier one with the grease grooves which last time i looked was still available.
Post by: Phil Ward (RIP) on June 08, 2019, 11:09:36 AM
I have just found a swing arm tube that I think is from a 900 that has same internal/external sizes but is longer. To save me stripping the K2 or CR swing arms to measure the size, has anyone got one that is off the bike that they can measure the length for me please?
Post by: Nurse Julie on June 08, 2019, 11:12:49 AM
Phil, if you cant wait till later, I will measure mine as my K2 is all stripped.
Post by: Phil Ward (RIP) on June 08, 2019, 11:14:52 AM
Thanks Julie, no rush as I need to fit the bushes I've just ordered from you and paint swing arm
Post by: Nurse Julie on June 08, 2019, 11:16:58 AM
Post by: casperdog on June 08, 2019, 01:59:38 PM
The one from my K5 is 232mm, measured with a rule. I can measure more accurately at work if you need. Are K5 and K6 the same...?
Post by: MCTID on June 08, 2019, 03:46:33 PM
Hi Phil,
My K4 Swing Arm Tube is 232mm Long X 21.26mm O/D X 14mm I/D.
Good luck.
Post by: Phil Ward (RIP) on June 08, 2019, 04:21:33 PM
Thanks Julie - much appreciated
