Other Stuff => Tricks & Tips => Topic started by: Nurse Julie on July 09, 2019, 10:56:10 AM
Title: HONDA CB VOLTAGE REGULATOR TEST ETC
Post by: Nurse Julie on July 09, 2019, 10:56:10 AM
I was rummaging around on Tinternet for something totally different and found this which may be of use if you are having charging probs. I will also post it in Anoraks Corner.
http://blacksquaremotorcycle.com/tag/honda-cb-voltage-regulator-test/
Title: Re: HONDA CB VOLTAGE REGULATOR TEST ETC
Post by: paul G on July 09, 2019, 11:11:04 AM
Just a note to anyone who is not familiar with Multi meters in the charging test, when you switch from volts to Amps this reading is taken in series with the battery lead.
 Make sure the meter leads are good for the 7-8 Amps ;)
Post by: Nurse Julie on July 09, 2019, 11:21:08 AM
I have no doubt you are 100% correct Paul. It's a dark art combined with Witchcraft as far as I'm concerned 😪😪😪😪😪
Post by: paul G on July 09, 2019, 12:31:11 PM
 ;D ;Djust says switch in the article  :o
Post by: rosco on July 09, 2019, 01:22:32 PM
Hi Julie Hope this has cured Grahams problem on the 750 brat
Post by: Nurse Julie on July 09, 2019, 01:46:31 PM
I bloody hope so Ross. I have given up asking him if he has found the problem......he goes a sort of purple colour with steam coming out of his ears  ::) ::) ::). TBH, I think he has sorted it, I have been riding it recently with no issues, so fingers crossed.
Post by: rosco on July 09, 2019, 02:06:11 PM
T ;Dold you the trouble was under the left hand cover??? All that time at night school not wasted then
Post by: Nurse Julie on July 09, 2019, 02:17:38 PM
Well, he has spent a lot of time under that left hand cover 🤔🤔😀😀😀
Post by: K2-K6 on July 09, 2019, 05:08:00 PM
He was uffing n puffing about that one even on his day out at Crich  ;D
Post by: Nurse Julie on July 09, 2019, 05:12:22 PM
Post by: Rob62 on July 10, 2019, 01:31:07 PM
VERY USEFUL LINK! THANKS FOR SHARING.
Post by: Menno on July 10, 2019, 03:51:46 PM
you can also simply try this:
https://www.youtube.com/watch?v=xF6WUvqC1Xc
Post by: mike the bike on July 10, 2019, 08:39:40 PM
Or use a clamp meter to check the current.  You don't have to break into the circuit and you won't need heavy duty meter leads.
