General => New Member Introductions => Topic started by: Hayden on January 04, 2009, 04:08:33 PM
Title: New Member
Post by: Hayden on January 04, 2009, 04:08:33 PM
New Member from Lincolnshire.  Hello my name is Hayden and I live in South Lincs. I'm a fabricator and currently build bridges for a living. I started off as a sheet metal worker and have moved through the industry to where I now build/refurbish bridges mainly for the rail industry.
About six years ago I bought a CB750K1 in bits that had sat in a barn for a number of years. Full of good intention of rebuilding it, its moved house twice and no further on ! Untill now that is. When I bought the bike I first thought it may be a K0 because of its early '71 reg- May.(Any one know of an older U.K. K1) ?
I gave the one of the apprentices at work dimensions for an engine stand and 24 hours later the engine is in the stand on my work bench with the top end off. Thanks Dec. My aim is to build a track bike that puts out about 100hp at the rear wheel and handles/stops like a modern'ish bike. I want it to look like an early 70's race bike but under closer inspection it has more up to date bits on it.
This is where I need HELP. I know nothing about improving the engine on a CB750. Cams,piston kits,valve spings,clutch etc. Who makes quality tried and tested parts ? Engine capacity ? 750,810,836,900 and did I see 970 ! ? As for the frame I hope to use one I will make myself from either cm4130,T45 or maybe the new Reynolds 631 tubing (due May). I will post pictures on my progress. Thanks. Great site. Hayden.
Title: Re: New Member
Post by: dave400 on January 04, 2009, 06:32:40 PM
Welcome and good luck with your project.
Post by: SteveD CB500K0 on January 04, 2009, 07:30:04 PM
Hello Hayden.
You should link up with John Burrin (he's the guy who owns this site) "JonnyB". He's in Rutland...
If you are seriously into performance, you need to speak to VoxHonda (he's in Holland) or the guys on www.sohc4.net/forums.  I know that there's a group of them over in the 'States who are arranging for manufacturing of special cranks and pistons etc to get to the magic "100 @ the wheel".
The site is similar to this (same s/w). Use the same username so that we recognise you!
Post by: pae on January 05, 2009, 01:40:53 PM
Welcome to the site. Sounds like a good project, keep us posted (with plenty of pics!!!)
Post by: Hayden on January 05, 2009, 08:26:31 PM
Thank you for your support
Post by: BigAl (Alan) on January 22, 2009, 06:35:56 PM
Hi Heyden,
Just arrived on the site, if you post your engine/frame numbers I have a reference book with the 'K' model record for your bike...leave the last 3 digits out (for security)
ie: 1000***
Regards Alan
Post by: SteveD CB500K0 on January 22, 2009, 06:43:51 PM
Hello Al.
Which book is it you are using?
Post by: JonnyB on January 22, 2009, 06:52:33 PM
Welcome Hayden, I think we're the only ones on this side of the country
Close Steve, I'm at the home of the Red Arrows (well at least until 2011) Scampton near Lincoln
Post by: BigAl (Alan) on January 22, 2009, 07:00:07 PM
Hi Steve,
Haynes Great Bikes...Honda CB750 by Mike Duckworth
Regards Alan
