SOHC.co.uk Forums => CB750 => Topic started by: ace cafe racer on August 02, 2019, 07:55:13 PM
Title: Removing outer gearbox cover
Post by: ace cafe racer on August 02, 2019, 07:55:13 PM
Forgive me if this is a stupid question but I understand the gearbox on a cb750F1 uses the same oil as the engine, being used to gearboxes with there own supply of oil. If I remove the outer gearbox cover will the total supply of oil be drained or just what is present in the gearbox?
Title: Re: Removing outer gearbox cover
Post by: Nurse Julie on August 02, 2019, 08:01:42 PM
Unless its sumping, ie oil not returning to the tank, no, it will be quite dry.
Post by: ace cafe racer on August 02, 2019, 08:05:24 PM
Thank you
