SOHC.co.uk Forums => CB750 => Topic started by: Andrew-S on September 05, 2019, 02:29:23 PM
Title: K1 brake wire rating?
Post by: Andrew-S on September 05, 2019, 02:29:23 PM
Hello folks,
One of the wires to the hydraulic front brake switch on my K1 is pulling/fraying away from its bullet connector/plastic sheath as the wires were pretty tight. So I need to do some repair work to both connectors and lengthen the wires slightly and want to reuse the original connector/sheaths - can some please advise to the wire rating?
Thanks,
Andrew
Title: Re: K1 brake wire rating?
Post by: Andrew-S on September 05, 2019, 02:58:31 PM
Found it!  - the rating is stamped on the black wire: 0.75  ::)
