SOHC.co.uk Forums => CB750 => Topic started by: Andrew-S on September 18, 2019, 09:42:21 AM
Title: Fitting Lower Tank Trim Strips
Post by: Andrew-S on September 18, 2019, 09:42:21 AM
The original lower tank trim strips on my K1 are a bit too brittle and cracked in a couple of places (particularly one side) to refit against Menno's lovely new paint - although I am considering it as they have aged nicely, unlike me.......
I have bought replacement replicas from DS which are not quite the same profile, but if I do use them I assume these are easily moulded using the tank brackets - the question is: do I also use heat from a hairdryer or is this not needed?
Thanks,
Andrew
Title: Re: Fitting Lower Tank Trim Strips
Post by: paul G on September 18, 2019, 10:05:32 AM
Andrew, mine went on fine with no heat just following the contour of the tank.
You may need to trim them to fit as I did.
Post by: Andrew-S on September 18, 2019, 10:17:39 AM
Thanks Paul.
