SOHC.co.uk Forums => CB750 => Topic started by: ace cafe racer on October 04, 2019, 01:19:02 PM
Title: tacho drive bolt
Post by: ace cafe racer on October 04, 2019, 01:19:02 PM
decided to fix one of my many oil leaks starting with the tacho drive, came to undoing the bolt that fixes the drive in, lo and behold it just pulled out seems no thread left on housing. What size should this bolt be, thread, length etc so I can helicoil back to what it should be.
Title: Re: tacho drive bolt
Post by: Trigger on October 04, 2019, 02:12:15 PM
That will be a JIS M5 but, not easy to helicoil . Measure the depth of the thread and see if there is any thread at the bottom. Someone may have put a screw in too short.
Post by: ace cafe racer on October 04, 2019, 03:21:51 PM
The thread length is 25mm. It was a job I wished I had never started lol. sometime in the past some owner had decided to use an o ring and a copious amount  of black sealant, wich at first I thought was the old seal, however after trying to remove it realised it was black sealant cleaned it up as best I could put the new seal in but then the fitting didnt quite go in so tapped the seal as much as I dare until I could get the cable in with the original bolt for now but it is a tight fit only bonus is its not leaking yet!!!
Post by: Trigger on October 04, 2019, 03:30:57 PM
I use a special  tool to get them seals in, its called a gudgeon pin  ;)
Post by: ace cafe racer on October 04, 2019, 03:33:42 PM
I had to resort to a 10mm long reach socket. Is 25mm the correct length?
