SOHC.co.uk Forums => CB350/400 => Topic started by: rosco on November 27, 2019, 04:27:59 PM
Title: Carb inlet manifold rubbers
Post by: rosco on November 27, 2019, 04:27:59 PM
Just got my inlet rubbers back from Ash who has softened them Now I've come to fit them and noticed there are two different types ( didnt notice when taking them off  DOH ) Two marked 1&4 Two marked 2&3 Obviously to fit each cylinder   Question is are the numbers fitted uppermost on the corresponding cylinder  IE  cylinder No 1   mark 1 to top  mark 4 bottom  cylinder No2 2 to top  3  to bottom  ETC   Ive searched all service manuals and nothing on removing / refitting  Cheers Ross
Title: Re: Carb inlet manifold rubbers
Post by: Nurse Julie on November 27, 2019, 04:32:11 PM
Yes Ross, 1,2,3,4 uppermost from left to right whilst sitting on the bike.
Post by: rosco on November 27, 2019, 05:18:03 PM
Thanks  Julie   It seemed logical but not certain due to the shapes being different I have fitted them to the carbs and they look right   Ref your carb screws Yes Gerben has fitted 12mm plus washer to mine   Cheers Ross
Post by: Andrew-S on November 27, 2019, 05:45:41 PM
As Julie says, plus I believe these are rare original fitment as the 'new OE' ones supplied by DS (and others) are un-numbered.
Post by: Erwin83 on December 04, 2019, 01:34:20 PM
On this topic: i recently got a set of (non-OE) replacements for my 400f. These are all 4 the same. They're <35 GPB for a set of 4, so the price is attractive enough.,,
I already pointed out to the (english) ebay seller, that the fitment is not ideal. He responded that he's sold over 200 sets, and they work fine.
My conclusion is: yes they work, but they don't work very well. It takes a lot of force to install the carbs all the way, even though the rubber is nice and soft.
Anyone have experience with this?
Post by: Nurse Julie on December 04, 2019, 01:38:45 PM
If all 4 are the same, they can't fit properly, as 2 are angled differently than the other 2. I can't see how they will be a good fit if not angled correctly. We are talking about manifold to carb rubbers aren't we, not carb to airbox rubbers which are all the same?
Post by: sprinta on December 04, 2019, 01:43:19 PM
Try a little silicon grease on the outer lip faces of the carbs and a little on the inner faces of the rubber tubes, I find that helps.
Post by: Erwin83 on December 04, 2019, 02:04:15 PM
We're talking about the manifolds indeed, between head and carb.
The offset of the middle two is limited (just 2-3 mm out of center or so), so this set is supposed to be just pushed/forced in the "angle".
With force, they do fit. And at 35 GBP for all 4 boots, I still think it's a good deal.
I'm just wondering if anyone else has this experience.
I used WD40, similar?
Problem was that before tightening the clamps, the carbs were pushed out again. Due to the angle.
Post by: Nurse Julie on December 04, 2019, 02:13:47 PM
Mr Honda didn't give them 2 different angles for no reason. When I put my manifold rubbers on after the engine rebuild, I got those 4 rubbers on incorrectly, as at the time I did not understand the significance of the numbers on them. Fitted incorrectly, they definitely pushed the bank of carbs out of alignment. I didn't have any air leaks but, you could definitely see opposing forces were at work. As soon as I took the manifold rubbers off and got them in the correct order, everything fitted like a glove and was perfect. I use a smear of red rubber grease on all the carb boots / manifold boots etc when fitting, never WD40.
