SOHC.co.uk Forums => CB500/550 => Topic started by: GTB981 on December 24, 2019, 04:05:48 PM
Title: CB550 K0 Float Bowl Gaskets
Post by: GTB981 on December 24, 2019, 04:05:48 PM
Need a set of float bowl gaskets for my CB550K0 after renewing float valves. Where`s the best place ? Thanks, Geoff.
Title: Re: CB550 K0 Float Bowl Gaskets
Post by: Bryanj on December 24, 2019, 04:10:37 PM
Same as 500, probably cheapest to get O ring kits from Gerben
Post by: GTB981 on December 24, 2019, 04:11:13 PM
Cheers, I`ll take a look.
Post by: GTB981 on December 24, 2019, 04:12:49 PM
What, as in a kit of O-rings ?  when I searched I couldn`t see carb o-ring kits.
Post by: Deano400 on December 24, 2019, 06:07:00 PM
Is this the kit you're looking for?
https://www.ebay.co.uk/itm/CB500-CB550-4-Four-Keihin-carb-O-ring-set-VITON-rubber-for-4-carbs/113717285384?hash=item1a7a141208:g:R2IAAOSwb9BaqsJ9
Post by: GTB981 on December 24, 2019, 06:13:02 PM
I guess so, but only need the float bowl ones.
Post by: Seabeowner on December 24, 2019, 06:18:45 PM
I used 68mm x 2mm Viton O rings. They were a tad big, but got them in the groove ok. Came off ebay.
Post by: GTB981 on December 24, 2019, 06:24:16 PM
Cheers for the dimensions.
Post by: GTB981 on December 24, 2019, 06:26:01 PM
Is 68mm O/D or I/D ?
Post by: peterengland on December 27, 2019, 03:32:08 PM
Have had the float bowls off my carbs a few times, never renewed the gaskets and has never leaked, guess I'm lucky ?
Post by: deltarider on December 27, 2019, 04:43:55 PM
Same here. The later model bowl helped.
Post by: sye on December 27, 2019, 05:18:33 PM
68mm x 2mm is 68mm I /D x 2mm section, so is 68mm I /D x 72mm O/D.
