SOHC.co.uk Forums => CB500/550 => Topic started by: Mr Helicop on April 12, 2020, 05:45:53 PM
Title: Broken cam chain guide
Post by: Mr Helicop on April 12, 2020, 05:45:53 PM
Thought the bike was rattling a bit more than usual and on inspection I found the broken cam chain front guide, the adjuster seems to work as it should and I can't see any other problem. Anyone of you guys seen this before? wear and tear or what might have caused it?
Title: Re: Broken cam chain guide
Post by: Bryanj on April 12, 2020, 06:06:19 PM
I think you will find thar the grooves in the cyĺinder are worn (those pins have no rubber left) which has allowed it to rattle up and down thus break.
I have seen it before but not often, could be it was assembled worn by a PO
Post by: Mr Helicop on April 12, 2020, 06:23:17 PM
Yes it was fitted as shown when I serviced the the head - I had no idea that the pins should have rubber on them, I take it the new one should have the rubbers which should cure the problem?
Post by: Bryanj on April 12, 2020, 07:14:33 PM
The rubbers are not seperate but the whole assembly is covered. You need to make sure that the "pins" fit tightly into the machined recesses
Post by: Mr Helicop on April 12, 2020, 07:18:43 PM
Thanks very much for your help, I will see how it fits when it arrives.
