SOHC.co.uk Forums => CB750 => Topic started by: gazadi on May 18, 2009, 08:24:02 PM
Title: points
Post by: gazadi on May 18, 2009, 08:24:02 PM
Fitting   condensers, points and setting gap and advice instructions???
Title: Re: points
Post by: Bryanj on May 19, 2009, 05:13:07 AM
Gap 0.35mm timing on "F" mark with static bulb, keep checking both as when you rotate the plate the gap alters and when you re-gap the timing alters.
Get both spot on and you will be well rewarded
