SOHC.co.uk Forums => CB750 => Topic started by: legin101 on May 25, 2020, 11:25:40 AM
Title: Negative or Ground
Post by: legin101 on May 25, 2020, 11:25:40 AM
Hi all i am reasonably ok with electrics and have a good idea how it works but i have a slight problem ive never come across before with the F2 its got a negative (Black) and a ground(Green) which ultimately go to the neg terminal of the battery. what is the difference and why.
nigel
Title: Re: Negative or Ground
Post by: Bryanj on May 25, 2020, 11:33:29 AM
Ground and earth are two terms for the same thing. All Honda loom earths are green but the heavy duty negative lead is black and positive red
Post by: mike the bike on May 25, 2020, 01:26:32 PM
And then the positive turns black 😃
Until you know what's what, best use a circuit diagram
Post by: Bryanj on May 25, 2020, 02:10:58 PM
Only turns black after its swiched on
Post by: mike the bike on June 06, 2020, 11:00:11 PM
If you connect it to the mains  it'll all turn black.
