SOHC.co.uk Forums => CB500/550 => Topic started by: nairb on May 30, 2020, 03:49:32 PM
Title: earthing the wire loom. cb550k3
Post by: nairb on May 30, 2020, 03:49:32 PM
Its ages ago i started the re-build for the 550.  In fact I have built a couple of other bikes since.....  So its the same old story - many years after the re-build started I finally returned to finish it.  The frame & bits have all been powder coated etc so its been well apart and now nearly all back together again.  Almost.
There is a earth strap from the engine to the battery.  Which is good.  But was there an earth strap from the engine to frame and/or a earth point on the wiring loom.  The wiring diagram shows a earth point.  So I need to earth it somewhere.  I cannot find an earthing wire from the loom.  Was it a bullet connector and wire to frame.
Digital cameras make re-builds much easier nowadays.  Back in 1995 when I started to fix the 550 the cameras were a bit pricey.
Ta
Nairb
Title: Re: earthing the wire loom. cb550k3
Post by: SteveW on May 30, 2020, 04:04:55 PM
Mine is a 550 K0 and the green earth wire is earthed to the left hand side bolt that holds the coil to the frame.
Post by: nairb on May 30, 2020, 04:56:21 PM
Just checked and so is mine as well.  Thanks.  Thick green wire.  I had looked on the electrical panel on the LHS.  Wrong place
The indicators are slow to turn over so I thought it might be an earthing issue.
I will run an earth wire from the battery -ve terminal to the frame also.  Then there cannot be any doubt
Ta
Nairb
