SOHC.co.uk Forums => CB750 => Topic started by: Andrew-S on June 01, 2020, 11:42:04 AM
Just refitting the brake caliper adjuster spring and found two D washers in the same bag, it seems there's a 6mm plain washer missing but wondered where these D washers are from?
Thanks,
Andrew
Could be calliper spacers, but look like the washers from the triple tee clamp
Thanks Phil, spot on!
Cheers,
Andrew
Triple tree clamp
Triple tree clamp
Yes, forgot to mention that in my 'excitement' above....... ::) ;D
Bloody yanks ! Its a Top Yoke!!!
I know it’s a yoke, but it’s also a triple tee in parts of the world :)
And Please don’t call me a septic 🙏
I see you are from the North East, spent several years in Southshields where they put a zebra crossing about 5 yards from every roundabout exit.
Would never call you septic. Its as somebody famous said "the UK and the US are two countries separated by the same language"
The crossings are just a test to see if drivers are awake 😳
No worries
Phil 👍
Yet supposedly based from England.
Why is it called a triple tree?
The Triple Tree was the name referred to the typical structure of Tyburn gallows, composed by a beam placed across the branches of two trees. The triangle shape of this structure provided it the name of the Triple Tree, used the first time in 1571, at the time of the execution of the Catholic cleric John Story.
I've known it as a 'triple clamp' since the early 70s..........just saying. ;D
Over here it's called the "bovenste en onderste kroonplaat" and i bet none of you can even pronounce that right ;)
I will have you know i speak perfect gibberish!!
Mr Google says that means “most beautiful and lower crown plateâ€
Nearly there, but to me in my best Neder lingo it's the 'bovenste kroonplaat'.............or top triple clamp if you like? ;D
Google doesn't speak bike lingo ;D (in any language!)
@Andrew: not bad at all, but it was the subject of the topic in the first place ofcourse ;D
That's it. I'm calling them a crownplate now. That'll confuse the yanks.
And everyone else.
