SOHC.co.uk Forums => CB750 => Topic started by: SPEN10000 on June 07, 2020, 01:26:08 PM
Title: CB750F2 sohc con-rod bolts
Post by: SPEN10000 on June 07, 2020, 01:26:08 PM
Hi all, i,m a new member asking a question about rod bolts for my CB750F" sohc Phil read replica. were can i get new con-rod bolts or can i re-use the old ones? any information would be welcome please.
Title: Re: CB750F2 sohc con-rod bolts
Post by: K2-K6 on June 07, 2020, 01:50:12 PM
Ordinarily and with no damage or reason to suspect they've been taken beyond normal operating conditions,  they are reusable and most engine builds don't replace.
They are torqued during installation within their elasticity limits,  so not taken through "yeald" as a stretched bolt application does.
13.0 to 15.9 lbs/ft rating from Honda manual.
Post by: Trigger on June 07, 2020, 01:50:39 PM
Welcome to the mad world of the SOHC. If they are OEM they can be reused as long as they have not been over torqued  ;)
Post by: SteveD CB500K0 on June 07, 2020, 02:21:04 PM
Welcome. We have a thriving set of PRR owners here. I'm sure they will be along soon.
Had one myself for a while:
[attachimg=1]
Post by: SPEN10000 on June 07, 2020, 03:28:22 PM
Hi Guys, thanks for your help, it is most welcome. i am sure i will be asking for more help as the restoration goes along. :)
Post by: Phil Ward (RIP) on June 07, 2020, 05:53:51 PM
Welcome - enjoy the forum (I had one too!)
Post by: SteveD CB500K0 on June 07, 2020, 05:54:20 PM
Picture Phil?
Post by: Phil Ward (RIP) on June 07, 2020, 06:27:40 PM
I'll try and dig one out Steve - I'll ignore the other comment Ken!
Post by: Phil Ward (RIP) on June 07, 2020, 06:33:17 PM
As requested
Post by: AshimotoK0 on June 07, 2020, 06:35:44 PM
What brought it home for me about re-using con-rod bolts is Honda  tell you to Plastigage the bearings which involve torqing up the nuts and then disassembly possibly a couple of times so technically on final re-assembly they are used.
