SOHC.co.uk Forums => CB750 => Topic started by: davefirestorm on June 09, 2020, 07:19:18 AM
Title: wheel bearings removal tools
Post by: davefirestorm on June 09, 2020, 07:19:18 AM
I wonder if anyone would be kind enough to let me borrow the tools needed to remove the wheel bearings in a pair of alloy wheels I’m going to use on my 1975 750F. Would leave a cash deposit till returned to you.I live near Northampton but would travel to collect/return the tools.Thanks in advance😁
Title: Re: wheel bearings removal tools
Post by: legin101 on June 09, 2020, 09:38:02 AM
As far as i am aware you dont need any special tools to remove the wheel bearings just material you may have lying around, i have a length of brass about a foot long insert through first bearing and knock the spacer to one side and work your way round the opposite bearing until its out turn wheel over and do the same to the other side.
Post by: casperdog on June 09, 2020, 09:41:14 AM
Hi, I made these to fit my K5 wheel. If they will fit your wheel you're welcome to borrow them.
Post by: davefirestorm on June 09, 2020, 01:48:36 PM
Very kind Phili live not too far away will pm you later thanks
