SOHC.co.uk Forums => CB750 => Topic started by: Phil9886 on July 14, 2020, 10:32:18 AM
Title: The final steps! About to install exhausts on my CB750k6. Any tips?
Post by: Phil9886 on July 14, 2020, 10:32:18 AM
Hi. I'm at the very end of my K6 project (10yrs!) And about to install the exhausts. I bought a brand new set of factory pipes from Honda when I first bought the bike plus a fitting kit from David Silver Spares (all Honda bits but they put everything in one bag). See photos. Everyone has been so helpful as I've put this together I just so here's if there are any "top tips" or things to be careful of before / as I install.  I guess they are worth quite a bit now so don't want to mess them up. Any help much appreciated as ever. Phil
Title: Re: The final steps! About to install exhausts on my CB750k6. Any tips?
Post by: Nurse Julie on July 14, 2020, 10:35:00 AM
Just fit everything loosely to start with to give you jiggle room so you can align everything prior to final tightening.
Post by: Andrew-S on July 14, 2020, 11:05:43 AM
as Julie says above - I've recently refitted the exhausts on my K1 and I fitted one complete side at a time (to use as a guide) starting with in the inner pipe (2 or 3) and don't forget to fit the clip to the rubber joining piece before you tighten it all, up as I did...... ::)
Post by: Phil9886 on July 14, 2020, 11:09:13 AM
Thanks. Will post a photo once done. Cheers. Phil
