SOHC.co.uk Forums => CB350/400 => Topic started by: Athame57 on July 25, 2020, 01:24:49 PM
Title: Coil sizes...universal or not?
Post by: Athame57 on July 25, 2020, 01:24:49 PM
There is nothing worse than finding something you've spent a lot of money on does not fit. I went to fit the new coil I bought of Worlds End MC and it is too short to fit into the brackets, also lacking a single wire terminal on the original....or am I to discover the CB400F of 1976 has a different size coils to a CB400F2 of 1978?
Title: Re: Coil sizes...universal or not?
Post by: Nurse Julie on July 25, 2020, 01:31:05 PM
Only the OEM Coils will fit correctly. Aftermarket could be any size so it's pot luck really.
Post by: Athame57 on July 25, 2020, 01:36:06 PM
Hi Julie
There is also this tiny single wire terminal on the original and lacking on this replacement, I don't know what that is. I think I had better send this back to 'Worlds End MC ' and try DSS!
Post by: Nurse Julie on July 25, 2020, 01:37:10 PM
Hi Julie
Sounds like  a good plan George.
Post by: JezzaPeach on July 25, 2020, 06:03:19 PM
Hi I bought the DSS aftermarket ones for my 500/4 and very happy. On mine each DSS coil had a + and - feed, and I just had to change the end of one DSS adapter lead on each to a female bullet connector.
The DSS mountings were the right length unlike a set I bought on eBay (and returned)
Post by: gtmdriver on July 26, 2020, 09:06:09 AM
No matter where you buy your coils check that they have the correct primary coil resistance. For contact breaker ignition the resistance should be at least 3 ohms. Any less and you risk arcing of the points with rapid contact breaker wear and condenser damage.
Post by: Bryanj on July 26, 2020, 10:22:06 AM
I think 5 ohm is needed for the 500/550 and smaller fours due to lower generator output
