SOHC.co.uk Forums => CB750 => Topic started by: sohc bob on August 03, 2020, 07:34:14 PM
Title: 750 f2 carb removal
Post by: sohc bob on August 03, 2020, 07:34:14 PM
Hi all
        Is there a specific side to pull the carbz out from a 750 f2 which makes it easier also anyone brought throttle cables for the f2 from david silvers if so are they any good
Title: Re: 750 f2 carb removal
Post by: whiteylfc on August 04, 2020, 05:15:31 PM
Either side is good to take them out and put them in.Theyre a pig to get back on, particularly if the rubber inlet tubes have hardened off...good luck..
Post by: Spitfire on August 04, 2020, 06:55:10 PM
Usually I remove the airbox undo the clips and cables and push down first, as to throttle cables I got mine (F1) from Silvers and have not had any problems, mind you this was way back in 2007.
