SOHC.co.uk Forums => CB750 => Topic started by: PJM47 on August 30, 2020, 09:22:42 AM
Title: Engine full of fuel and seized up
Post by: PJM47 on August 30, 2020, 09:22:42 AM
Hi all,
I have a CB750K2 which was running fine, I haven't used for a few weeks and when I went to start it yesterday it turned over very slowly then the engine just locked up completely. It is now stuck solid, kickstart or rear wheel in gear won't move it. On investigation i discovered to my horror that I had what seemed like an entire tank of fuel inside the engine! I left the fuel tap on and somehow the carbs leaked into the engine and gearbox rather than come out the overflow. I have drained all the fuel and removed the plugs but the engine is still stock solid. Any ideas of what the damage might be? Is there any thing I can check to narrow it down, not sure I am up to a complete engine removal and strip down?
Title: Re: Engine full of fuel and seized up
Post by: Johnwebley on August 30, 2020, 09:27:13 AM
Take the plugs out.
Try to turn it in reverse.
See what happens
Post by: PJM47 on August 30, 2020, 09:36:08 AM
Hi, thanks for the reply. Plugs are out, tried turning it forward and reverse with the rear wheel whilst in gear and it won't budge at all.
Post by: PJM47 on August 30, 2020, 09:48:37 AM
I don't think there is fuel left above the pistons now, but the engine is locked solid, like something mechanical completely jammed there is no give at all.
Post by: K2-K6 on August 30, 2020, 09:54:47 AM
Cases like this have sometime resulted in bending the conrods from hydraulic locking above the piston.
Not a nice prospect,  but  a very real possibility.  Difficult to assess though without some level of dismantling,  if it's not turning with the fuel drained from it then obviously some mechanical change could have taken place.
Post by: K2-K6 on August 30, 2020, 09:56:05 AM
With plugs out,  can you turn it backwards with the rear wheel?
Post by: Nurse Julie on August 30, 2020, 09:57:36 AM
I don't think the fuel in the engine has anything to do with it. The engine should still turn over but there would be a sloshing noise in the bottom end.
Post by: Bryanj on August 30, 2020, 10:12:18 AM
Unfortunately the hydro lock is most likely and you will have to remove and strip the engine to be sure
Post by: ka-ja on August 30, 2020, 10:22:04 AM
At least a "head" off and valve check.
Post by: Bryanj on August 30, 2020, 11:57:06 AM
Im fairly certain cylinders will have to come off as well to find out whats wrong
Post by: Lobo on August 30, 2020, 11:59:06 AM
...if the engine turned slowly, and then not at all, hopefully the forces involved were a gradual build versus an instant shock to the Conrods etc. Fingers crossed.
Is it possible, that fuel has pooled in the sump below the pistons and locking from below... ie have you taken the sump plug out / oil filter off to drain all fluids as the next step?
Post by: Johnny4428 on August 30, 2020, 12:12:08 PM
Interesting to see if it moves with plugs out and full fluid drain, if it’s stuck still stuck then it’s full strip down.
Post by: PJM47 on August 30, 2020, 12:14:51 PM
Yeah sumo drained, spark plugs out, still stuck solid, sounds pretty terminal, any ome know a good engine repairer?
Post by: McCabe-Thiele (Ted) on August 30, 2020, 12:41:10 PM
I'm gutted for you as I understand it you have had plugs out, drained the sump and its still solid - that sounds serious.
When you removed the oil filler cap did flud run out then?
Not sure from your description if you cranked the engine with the electric start or with the kickstart it needs a fair bit of pressure to bend a con rod.
I've seen flood damaged engines on Petrol & Diesel engines from when I worked at local MB dealership for 11 years - they tend to bend and often snap con rods or push them through the block as well as piston & valve damage. That said the damage was done when the engine was running. i would expect your damage to be more limited as it was done when attempting to start the engine so less force in play.
Post by: Bryanj on August 30, 2020, 01:27:35 PM
Remember Suzuki GT 250, they bent rods whent fuel tap diaphragm went and that was at kickstart speed.
Post by: K2-K6 on August 30, 2020, 03:50:56 PM
IF it has bent a rod,  then it's better to leave in without significant force applied to avoid additional complications I suppose.
Detecting accurately without internal inspection may be difficult,  at least I can't immediately think of a competent way  :)
It takes only a small amount of fluid (anything much above tdc combustion chamber volumes) to compromise a rod.  It's even more effective with less total volume error above chamber volume as the crank can build more approach speed until it meets resistance,  and finally tweak the rod as it won't go over compression.
Vaguely better news ( again,  if this is the cause) is that it may be only one piston as it's pair cylinder would have valves open at the same point. If that's the case,  then damage may be very minor with just one piston cocked side ways and locking the crank.
Post by: Lobo on August 30, 2020, 10:53:06 PM
I’ve thankfully little experience of bent conrods - but would an accurate measurement down the top of the bores (ie through the spark plug hole) show up a difference between two companion pistons?
That’s said perhaps a waste of time as this does sound to be a head off. Feeling bad for you PJM47..., and kinda wondering why we don’t hear more of such failures given the number of CBs out there...
Post by: MrDavo on August 31, 2020, 11:18:35 AM
Commiserations for your loss.
My wife, acting as designated driver on the way home from a bike club ‘do’, once drowned my 2.8 V6 Capri, by driving it through a flood. The air intake was quite low down, next to the headlights behind the front grille.  We got out, getting us and the interior very wet, and pushed it to safety, then idiot here decided to try and bump start the car. No joy, it wouldn’t turn over,  and the next day when I took the plugs out, jets of water shot out of the plug holes as I cranked the engine.
I got it running again, but with a loud death rattle, which turned out to be displaced main bearing shells if I remember correctly. I do know I had to pay a shedload of money to have it fixed.
Post by: PJM47 on August 31, 2020, 11:29:03 AM
Thanks for all the replies an sympathy :) It was only turned over a few times on the starter so maybe damage isn't too severe. Every part was completely full of fuel though. Anyone have an idea of how much an engine strip and rebuild would be or would i be better of looking for a complete replacement engine?
Post by: Bryanj on August 31, 2020, 12:13:18 PM
Always take it apart and asses what is needed first, you may not need as much as you think you may need more and a used engine is an even worse unknown quantity---pay a fortune and get crap!!
Post by: rosco on August 31, 2020, 05:02:07 PM
Have you thought it could be the gearbox stuck???  My brother bought a cb550 with a "seized engine " Turned out something in the gearbox let loose [ can't remember what ] and jammed the gears and broke a few teeth Try pulling in the clutch  and using the kickstart  If the kickstart don't move its the gearbox If it does move more than likely engine  Good luck   R
Post by: royhall on August 31, 2020, 05:39:48 PM
For what it's worth I think I would take the clutch plates out and try and gently turn the crank with a spanner on the timing end. It's going to be tight as it will have washed every bit of lubrication out on the engine. Oil pump strip required at the very least. Starting it now with petrol washed through the bearings would be a big risk that could cost a crank. Only real safe route is an engine strip.
Post by: Bryanj on August 31, 2020, 05:47:00 PM
DO NOT TURN THE CRANK AT THE TIMING END
If you try you will wreck the advance unit. If you want to try turning the crank remove the generator cover and try on the big bolt holding the alternator rotor
Post by: royhall on August 31, 2020, 05:59:37 PM
Why would you wreck the timing unit, that's how you get tdc to set your timing? I'm not meaning to put a drill on it and spin it up at a 1000rpm, just a few very gentle mm's with the big keyed to the crank special nut (as Honda Calls it). Or have I lost the plot again. LOL.
Post by: PJM47 on August 31, 2020, 06:58:45 PM
So in neutral with clutch held in the kickstart still won’t move. Does this mean more likely a gear box problem? I can select neutral and gears ok.
Post by: K2-K6 on August 31, 2020, 07:35:33 PM
It doesn't turn on the starter either I thought.
Kickstart essentially bypasses the gearbox on these by just going down through the primary chain to the crankshaft, hence you  can pull the clutch and start it whether it's in gear or not.
Post by: Bryanj on August 31, 2020, 11:36:32 PM
The only thing holding the advancer in time with the crank is a solid small dowel pin, if you put a lot of torque on the big nut you will snap off the ears on the advance cam, if you put too much torque on the 6mm stud you will snap it off.
It is only permissible to use that big nut with plugs out on a free turnung engine and its not really advised even then
Post by: royhall on September 01, 2020, 07:14:48 AM
As always Bryan you are correct, that was me thinking out loud. I have made the incorrect assumption that everybody works like I do. By that I mean when I do anything on a bike if it wont turn or assemble correctly I assume there's something assembled wrongly, broken, or I am doing something wrong. I therefore never ever use force on anything without first appraising the situation as that usually just makes things worse.
I should make it clear now that I used the words gently and very gently and only millimetre movements. It was not my intention to use the timing end it break the engine free with a scaffold pole, just to establish which part of the engine is locked.
It may be wise to establish the facts here. Firstly what level of mechanical competence does PJM47 have, I assume as he's talking about repair engineers he's not a professional. Are you a competent DIY mechanic or a complete novice or somewhere in between. Was the bike left on the side or main stands? On the main stand the leak would fill the airbox first as the intake side is slightly lower (on the F2 anyway). If it cannot escape from the airbox as the petrol level rose it would then fill all 4 cylinders via the airbox. The cylinder with two closed valves would hold fuel in the intake so when the engine turns that fuel gets drawn into the cylinder and before it can leak down past the rings the engine comes back to compression and bends a rod or tips a piston jamming it into the bore.
Also, just how much petrol are we talking about here, you appear to say it could be around 2 to 3 gallons sat in there over a good few weeks? With the limited space inside a CB750 engine that is enough to fill the thing from top to bottom. If that is the case, a complete strip and rebuild is the only way forwards. The fuel will be in all the bearings, oil pump, oil galleries, alternator, clutch, scavenge lines, oil filter etc etc. Even if you can achieve turning the engine again it would require careful work to safely run it again. If there's fuel in the oil galleries clean oil would need to be slowly pumped through the engine to re-lubricate everything with the sump plug out to drain the fuel pushed through. You would need to remove the scavenge line to the oil tank to prevent fuel contaminating the oil in the tank. And don't forget were also talking Ethanol here that loves to remove lubricating oil.
In my view this engine needs stripping to clean everything out and re-lubricate everything and locate the damage. The alternator needs cleaning and drying off and testing. I many years ago foolishly cleaned some clutch plates off a Suzuki in petrol and the corks grew to about twice the thickness they should be which cost me a clutch, so that will need checking. Then lets not forget the failure in the carbs that allowed this to happen that also needs sorting, plus the airbox will be full of fuel.
If it were me I would take out the clutch plates to disconnect the engine from the gearbox physically then put the bike in gear and gently turn the back wheel and see if the clutch inner turns. That verifies the gearbox is not locked and it's therefore in the engine/kickstart mechanism. At that point see if the engine turns (please do this very gently). But that only establishes the area the damage lies and the engine will need stripping anyway.
Sorry to be the bearer of bad news and I do sympathise whole heartedly with you. But if the bike was mine I would bite the bullet and get the engine out. It's a big price to pay for forgetting to turn off the fuel tap, and not one of us on here can say we have never done that, we just got away with it.
Post by: PJM47 on September 01, 2020, 06:03:17 PM
I’ve taken the clutch out and the rear wheel/clutch inner turns ok when in gear. Kickstart still won’t move. Like you say no point forcing anything, if it wasn’t broken it would turn easily with the plugs out.
I’m a fairly competent diy mechanic and will tackle most jobs but obviously this is pretty major and might be best left to a professional, ouch!
Post by: rosco on September 01, 2020, 06:19:48 PM
If your looking for a pro to rebuild your engine  "Trigger " on this forum is your man and Julie makes nice Tea!!!!
Post by: K2-K6 on September 01, 2020, 06:26:20 PM
If you're comfortable with checking the clutch,  then it's not much different to pull (actually easier) the alternator cover off and try to assess crankshaft movement just by turning the rotor with you hands and a rag wrapped round it.
Some oil will drain out but not much,  just residual.
Also in the interests of investigative examinations,  could be worth removing the float bowls and trying to gently blow,  mouth? Not compressor,  down the overflow tube to see if any are blocked which would cause the fuel to exit via jets into carb throat. It may illuminate which cylinder the fuel was routed through.
Which area of Hampshire are you located?
Post by: rosco on September 01, 2020, 06:52:50 PM
Have you tried to turn it over in each gear to eliminate the box  If all ok  and engine won't turn on either kick start or button  likely to be engine locked up  Agree with Roy best to take engine out to investigate  First check cam chain ok
Post by: PJM47 on September 01, 2020, 07:31:32 PM
Ok ta, will whip the alternator cover off and have a look tomorrow. All gears seem ok. Haven’t investigated the carb problem yet as this will be minor compared to the damage it’s caused. probably one iof the overflow pipes blocked which in combination with a leaking float needle and leaving the fuel on ended in disaster. I’m in PO8 area of Hampshire. No hurry to get this fixed, probably an over winter job and I don’t mind paying a reasonable amount or supplying as much tea/beer/bacon as needed. It is (or was) a nice bike.
Post by: K2-K6 on September 01, 2020, 07:35:19 PM
The kickstart engages a gear directly on the clutch basket,  which in turn is directly connected via spline drive to the primary chain coming from the crankshaft.  By removing the clutch plates the gear ratios have no connection at all with the engine / crankshaft assembly.
The OP should be able to turn the centre shaft of the clutch (rotaing the gearbox) and demonstrating it's free,  but not the clutch outer basket as it's still directly connect to crankshaft.
Post by: PJM47 on September 02, 2020, 12:40:10 PM
Yeah inner of clutch is free outer is stuck. No movement at all at the alternator it’s locked completely solid.
Post by: K2-K6 on September 02, 2020, 04:58:59 PM
Realistically the last place of acces without removal from frame is to take the sump off and check the chains (primary and cam) to asses if anything obvious is amiss there. Would help if you have one of those usb camera scope to use on phone or tablet to look up into the crank cavity,  can't think of anything else useful to look at without stripping.
Oh! with a scope you can also look at the cam chain at the top through #3 inlet tappet cover to make sure it's not snapped.  That's a pretty remote half chance and highly unusual but very remote possibility and worth a look-see.
Post by: PJM47 on October 05, 2020, 05:20:52 PM
So I've had a bit more time to look at this now. I can actually turn the engine over at the alternator, probably wasn't trying enough before. So that is good. When in gear though I can't turn the engine with the rear wheel and the kickstart is still locked solid. With the clutch removed the inner turns ok. The outer clutch basket I can't move by hand but it turns when I turn the engine over with the alternator bolt. I can select gears ok and i can select neutral. I guess this is a gear box issue? Maybe as a result of trying to use the kickstart when the starter wouldn't turn the engine when it was full of fuel, does this sound logical? Any ideas what might have broke?
Post by: Nurse Julie on October 05, 2020, 05:30:03 PM
It sounds like a kick start issue. Put the bike in 5th gear and try and move back wheel.
Post by: Trigger on October 05, 2020, 05:32:17 PM
Take the clutch basket out and see if the kick start will move  ;)
Post by: JonnyB on October 05, 2020, 05:46:48 PM
I'm with trigger. you need to ascertain if the engine will turn over. Normally with it in neutral the engine will turn over easily with a spanner on the crankshaft end.
If not  remove the clutch or just the plates. if it still won't turn over it's engine. if it does it's clutch or gear box.
I've not read the whole post. have you drained the sump since? I've had this issue on a GS450. it locks the top and bottom and the clutch plates can bind.
Sent from my SM-G935F using Tapatalk
Post by: royhall on October 05, 2020, 05:59:53 PM
That's all been covered earlier in the thread.
Post by: PJM47 on October 05, 2020, 06:30:14 PM
So clutch basket is now out and the kickstart now turns freely. The rear wheel also turns freely now when in gear. The engine still turns over on the alternator nut. Not sure wher that leaves us?
Post by: Trigger on October 05, 2020, 06:47:53 PM
Are you turning the alternator anti clockwise as you look at it ?
Check the teeth on the clutch basket and check the teeth on the kick start wheel. Also make sure the kick start cog/ wheel is running true as in not bent.
If everything looks good then put the basket back in and try to kick it in neutral.
Post by: PJM47 on October 05, 2020, 07:01:25 PM
Yes anti clockwise, it actually turns both ways. will check things you suggest and and try the basket back on tomorrow.
Post by: PJM47 on October 06, 2020, 07:56:04 AM
Clutch basket back in and ithe kick start won’t move again. Teeth on kickstart and clutch basket all good.
Post by: Trigger on October 06, 2020, 08:22:31 AM
With the basket out can you turn the kick start cog with your hand ? It should turn forwards and you should hear the ratchet clicking.
Post by: PJM47 on October 06, 2020, 10:57:29 AM
The kickstart cog turns freely in either direction no ratchet clicking but with a slight downward pressure in the kickstart lever the cog will then only turn anti clockwise and you can gear the ratchet sounding normal.
Post by: Trigger on October 06, 2020, 12:19:23 PM
Right, that all sounds fine on the kick start.
Now without the basket in can, you turn the shaft easy and select all gears that way ?
Do you have the transmission cover off ? I would like to see a picture with that cover off.
Post by: PJM47 on October 06, 2020, 01:58:56 PM
hi, yes shaft turns easily in all gears. Gears and neutral all seem to select correctly.
[attachimg=1]
Post by: Trigger on October 06, 2020, 02:11:48 PM
Everything looks good behind the misson cover.
Now, this is not making any sense. The kick start cog turns the clutch basket with is on the shaft. If the kick start is working fine and it sounds like it is, then the kick should turn the basket which, turns the shaft.
Post by: K2-K6 on October 06, 2020, 02:19:41 PM
Could be that the starter sprag clutch was jammed so trying to turn the starter motor (from mechanical means) all the time.
Could try removing the starter motor and see what you get.
As Graham says, it's not adding up so something we're missing somewhere.
Post by: PJM47 on October 06, 2020, 02:24:44 PM
It's not making sense to me either. The basket rotates if the engine is turned using the alternator bolt so that must be free. The kickstart rotates if the basket is not fitted so that must be free. All gears select ok and the rear wheel turns in any gear without the basket fitted. But with the basket fitted the kickstart will not move and nor will the rear wheel.
I'll have a look a the starter next. Is it easy enough to remove?
Post by: Trigger on October 06, 2020, 02:29:21 PM
The part that i have indicated  Blue pointer is the basket mount and will move when you turn the crank. The part indicated Red pointer is to the gear cogs and should only move when in gear.
[attachimg=1]
Post by: Trigger on October 06, 2020, 02:38:44 PM
If the alternator housing is off, all you need to do is remove the small cog that connects the flywheel to the starter motor so, no need to remove the starter  ;)
Post by: Primus on October 06, 2020, 02:58:10 PM
Sorry, I don't have any technical input to offer but I am enjoying this thread (in a perverse sort of way!). I really hope there is a successful conclusion to PJM47's issue.  It gives me the confidence should I encounter a serious issue that I can't resolve, that there is help out there. I'll continue to watch from the sidelines.
Paul
Post by: K2-K6 on October 06, 2020, 03:01:57 PM
Ooops, I forgot the alt cover was off  :)
Also then,  can check the sprag clutch by rotating the big gear, should try to turn turn the crankshaft if pushed anti clock,  and spin freely if you rotate clockwise.
Post by: royhall on October 06, 2020, 03:21:51 PM
Don't forget when the basket is out all turns well so not going to be starter or sprag clutch. My money's on the part that trigger posted a picture of, something has seized in that. That's the union piece between the two halves of the engine. This is like a whodunnit murder mystery.
Post by: PJM47 on October 06, 2020, 03:40:21 PM
So looking at the picture the Blue arrowed part moves when I turn the crank. The red arrowed part moves when in gear and I turn the rear wheel. I put the basket back in one more time just to check and the kick start won't budge with basket in.
I also removed the cog that connects to the starter motor and this made no difference.
Post by: K2-K6 on October 06, 2020, 03:43:54 PM
A question PJM47, when you turn the crankshaft with the alternator,  how far is that turning?  Can you rotate it complete revolution in both direction?
Post by: K2-K6 on October 06, 2020, 03:47:46 PM
I was thinking the same Roy,  but with all assembled AND in neutral,  then the whole lot  can go round unimpeded.  Very puzzling.
Post by: PJM47 on October 06, 2020, 04:07:39 PM
Yes will turn completely revolutions in either direction
Post by: Trigger on October 06, 2020, 05:01:20 PM
I can not come up with anything else, i would have to see it up close and personal to see what is going on.
I would say, pop the engine out and throw it in the car and bring it to my workshop but, it is not that easy to just pop a CB750 SOHC engine out.
Post by: K2-K6 on October 06, 2020, 05:23:37 PM
Worth pulling the sump off and having a look up in there.  It's pretty easy as doesn't disturb anything.
See if you've any "spare parts" lying in there.
Oddly I was in your area 3 weeks ago to collect a tent I bought on the bay of E, and was followed by an F2 along the old A3.
If you can't take up Trigger's offer I could come down to have a look with you at some point.
Post by: McCabe-Thiele (Ted) on October 06, 2020, 05:34:27 PM
This post is a real mystery it will be a revelation when the cause is found. :-\
Post by: MrDavo on October 06, 2020, 06:03:52 PM
We should have a sweepstake.
No idea what, but given the circumstances in which it happened, my money is on something, maybe in the gearbox, being bent, which isn't going to unbend itself. Maybe it wants to be in an 'impossible' gear.
Unfortunately the only way to find out what, and fix it, is to dismantle. When my crank went up the pictures I got my engine out in an afternoon (with help with the lifting), you can then turn it upside down and split the cases without touching the top end, if I remember right. If not someone will be along soon to call me an idiot.
Then K2-K6 will tell me how long Honda allowed for an engine removal....
Post by: K2-K6 on October 06, 2020, 06:59:40 PM
 :) "Then K2-K6 will tell me how long Honda allowed for an engine removal...." I'm not from official workshops so haven't a clue  :D Bryan and Ken usually know that in more detail.
Lifted many of them out though,  in a more relaxed fashion  :) usually trying to be real careful not to scratch anything.
Post by: PJM47 on October 06, 2020, 07:13:06 PM
Thanks for all the offers of help folks. Gives me confidence to get on with it knowing there’s help if I get stuck. I am resigned to engine out now but just wanted ideas of what it might be and what to look for before I start as the symptoms didn’t make much sense. Hopefully it will become clear with the engine out. I’ll keep you posted on progress, it is an interesting one.
Post by: Trigger on October 06, 2020, 07:22:29 PM
I can't remember what the book says on hours for a engine removal on a 750 but, i had a customer that had a quote for £665 engine removal on a 750 then the same again to get it back in plus £45 a week storage charge for the rolling chassis until i rebuilt his engine and then £225 set up fee including tuning  :o
Post by: K2-K6 on October 06, 2020, 07:27:01 PM
You'll have to take the sump off to get it out anyway,  so might as well have a sneaky peak now to see if you can spot anything.
Post by: Trigger on October 06, 2020, 07:29:43 PM
Show us a picture of the inside of the sump pan. We love pictures on here  ;D
Post by: MrDavo on October 06, 2020, 08:26:12 PM
Blimey, I’d take engines out all week for £665 a pop. I’d need my 6’7” human engine hoist mate too, but he’s happy to work for cups of tea.
Post by: royhall on October 06, 2020, 09:02:22 PM
I think that's a classic case of pricing yourself out of the job because he didn't want to do it.
Post by: SumpMagnet on October 06, 2020, 09:12:29 PM
I've only taken one 750 motor out...and it was a traumatic experience. Also invovled a quick break to visit casualty after I cut my hand doing it when the motor slipped and a fin squished my hand against the frame. Still...it's all part of the learning curve.
Having shifterd a KAwasaki 750 motor on my own before...I was unprepared for just how damn heavy the 750-4 engine is
Post by: Trigger on October 06, 2020, 09:27:34 PM
Nope, as i asked about and that is a standard rate these days at a main dealer. They would have to carefully store the exhausts, tank,  side panels and the rest of the bike. Then not damage the bike frame in any way or the customer could claim.
Post by: royhall on October 06, 2020, 10:21:01 PM
Wow. £1330 to take take an engine out and put it back again. I'm in the wrong job. Bloody hell!!
Post by: Trigger on October 06, 2020, 11:23:01 PM
It is all down to workshop overheads. I used to turn the key in the workshop door on a Monday morning knowing that i would have to find £3,200 by the end of the week to pay staff, rent, rates, electric, phone bills, insurance, heating, water rates and many, many other bills and, that was back in the 90's. Would not even like to work out what it would cost to run a workshop with staff today .
Post by: Bryanj on October 07, 2020, 12:59:24 AM
There used to be FRT times in the parts books, i seem to remember a 550 crank swop was 8.5 hours
Post by: royhall on October 07, 2020, 04:52:13 AM
Your probably right. At something like £70 an hour that gives you around 9 hours to do the job. That's not an unreasonable amount of time for getting the engine out of a 750 and packing all the bits away safely. Just sounds like more than anyone would consider worth spending. You would really need to have no mechanical ability whatsoever to pay out £1330 just to get an engine in and out. After all that's the easy bit as it's just nuts and bolts, Triggers then going to do the hard bit with the rebuild. It would total more than the bikes worth surely.
Post by: Bryanj on October 07, 2020, 07:41:45 AM
Just nuts, bolts and a hernia plus 2 boxes of elastoplast
Post by: royhall on October 07, 2020, 07:43:17 AM
Forgot about that Bryan, the charge for the physiotherapy.
Post by: paul G on October 07, 2020, 07:45:55 AM
Plus a week of work with a bad back  :o :o
Love the 400/4 engine as it can be done in the frame  ;D ;D
Post by: JezzaPeach on October 07, 2020, 07:46:59 AM
Could it be the petrol caused something like a piece of the cam chain tensioner material to come off, or a bit of debris from the top end, and drop down into the gearbox? Again maybe that would be visible by removing the sump pan. On my 500 it was easy and an opportunity to remove sludge, check the strainer and put a new seal on. 🤞
Post by: flatfour on October 07, 2020, 08:47:06 AM
I have a friend who runs a small private medical practice, providing health services to companies. He says that every day that the nurses cannot travel and work in a company costs him £5,000.
Post by: Trigger on October 07, 2020, 10:54:47 AM
Not just nuts and bolts Bryan. Lost count of how many frame bolts i have had to oxy out.
We used to charge £85 to fit a exchange engine in the 90's and some customers thought that was too expensive and decided to take the engine out themselves. Had a few customers that had dropped there engine off a trolley jack while trying to save money. Even had one macho man who, instead of coming into the workshop and asking for help to get this engine out of his car, decided that it was a good idea to take it out himself, dropped it, then fell over it and broke his nose when he hit the floor  :o
Post by: royhall on October 07, 2020, 11:08:25 AM
Priceless.
Post by: Bryanj on October 07, 2020, 02:02:56 PM
Just trying to throw in a bit of light, or should that be heavy, humour.
We found that it was easier for just one, strong, person to lift from box to frame and then the "helper" to get involved from other side of bike, this was when we were allyounger, healthier, fitter? and of course a damn site stupider
Post by: 71 V12 on October 07, 2020, 05:37:43 PM
I have not tried this myself but they do make it look easy. Anyone tried to pull a 750 this way?
https://youtu.be/Ezl3B5Jv6B8
Post by: PJM47 on October 07, 2020, 05:49:48 PM
Started the strip down. Nothing obvious in the sump.
[attachimg=1]
Post by: Nurse Julie on October 07, 2020, 05:53:48 PM
Was there any debris or bits the sump pan?
Post by: PJM47 on October 07, 2020, 06:20:46 PM
No debris at all came out.
Post by: Trigger on October 07, 2020, 06:28:38 PM
That is one clean engine inside  ::)
Post by: PJM47 on October 07, 2020, 06:36:17 PM
Probably that petrol wash it had!
Post by: K2-K6 on October 07, 2020, 06:40:42 PM
 ;D ;D
Post by: Trigger on October 07, 2020, 07:21:42 PM
Well, it did not wash the coating off the inside of the engine. Are you sure that this is a K1 engine ?
Post by: SteveW on October 07, 2020, 09:48:54 PM
This is one of the best threads ever.
Almost as good as when I was a kid eagerly waiting to find out who shot JR in Dallas.
Post by: Nurse Julie on October 07, 2020, 10:01:34 PM
It's sort of like a murder mystery, I'm really enjoying it as well.
Post by: Laverda Dave on October 07, 2020, 11:12:29 PM
I don't know anything about the 750 engine but looking closely at the sump off photo and zooming in on what I think is the kickstart gear can I see a chip on one tooth or is it the light playing tricks? It's the tooth closest to the back of the crankcase casting. If the tooth is damaged could the chip be stuck somewhere in the engine causing the partial lock-up?
Post by: Phil Ward (RIP) on October 08, 2020, 01:42:44 PM
That's a good spot Dave! Looking on my phone screen, I can see what you mean
Post by: PJM47 on October 08, 2020, 06:36:49 PM
I didn't spot any chipped teeth but will have a closer look when the engine is out. The bike is a K2 BTW, engine number is CB750E-2060793 which I think is consistent.
I have everything stripped now ready for engine removal so hopefully won't be too long before the next instalment..
Post by: Trigger on October 08, 2020, 06:52:38 PM
I don't know why i had K1 in my head and yes it is a K2. I can tell from the pictures that it has not been apart since the factory put it together  ;)
Post by: Lobo on October 08, 2020, 11:28:44 PM
I’m no engine builder, but if the guts have been washed of oil in the petrol soak (a few weeks ago now) would it be worth spraying some kind of rust inhibitor asap about the internals?
Post by: PJM47 on October 10, 2020, 02:50:24 PM
Engine out, it was actually quite easy, did it as per this https://youtu.be/Ezl3B5Jv6B8 suggested by 71 V12 below. I also added a motorcycle jack underneath to position the engine in about the right spot to come through the frame before attempting it. But it worked fine.
I have split the cases and everything looks ok. There wasn't a drop of oil anywhere though, everything had been washed clean by the petrol, so I oiled everything up I could and the engine started to turn over much easier on the crank, the more I turned it the better it got. I am now able to turn it a bit on on the kick starter, there is no way I could do this before. I'm not sure there was ever anything much wrong with the bottom end, could it be it was all just a bit seized up?
Do we think the issue was just that the pistons had seized up a bit after sitting in petrol for weeks and no oil and were reluctant to move, this might be consistent with the start of this thread where a few weeks ago I'm sure I couldn't turn it on the crank at all. Then when I tried again the crank would turn but it was still too stiff for the kick starter.  Then finally after taking apart and oiling it is now free enough to move on the kickstart (a bit). It does seems to be gradually freeing up which would explain why the symptoms are changing and not making sense.
So what next? how easy should it be to turn the engine over (no plugs and lower case removed) on the crank, it's still seems a bit stiff and has tight and loose spots? But after a lot of turns I can now turn it a bit on the alternator just by hand, not all the way round though that steel needs a wrench. Is that normal?
What can I check to get a good feeling it is safe to put back together and try to start it?
And finally anything I should replace/check whilst its apart?
Post by: Nurse Julie on October 10, 2020, 03:03:34 PM
What's this circled in red? (It could be something or nothing, difficult to tell on my phone)
[attachimg=1]
Post by: K2-K6 on October 10, 2020, 03:35:32 PM
That description still sounds wrong to me "tight and loose spots" have you any pictures looking up the bores of the top half?
I've still a suspicion it's tweaked a rod from hydraulic compression,  can you equate the tight spot to a regular positioning of one pair of con rods?
It should rotate with very similar friction for whole rotations just by hand on the alternator.
Pretty simple to work on though,  aren't they?
Post by: Trigger on October 10, 2020, 04:25:46 PM
I would pull the pistons out as it many be a broken ring. I had a engine in once that one part of a three part oil ring had got out of the ring groove in the piston and had folded up the side of the piston.
Can't see anything in the bottom end. Are all the cog teeth OK, no chips ?
Post by: PJM47 on October 10, 2020, 04:41:15 PM
Just a bit oil, cleaned off and there's nothing there.
Post by: PJM47 on October 10, 2020, 04:48:30 PM
All gears and teeth are fine.
The conrods don't look obviously bent but I guess it would be difficult to tell.
It is tighter when pistons 2&3 are down (compressed) and fairly loose when they are the way out.
So can I get to the pistons / conrods without opening the top end or is it now major strip down?
[attach=1]
[attach=1]
Post by: PJM47 on October 10, 2020, 04:49:59 PM
[attach=1]
Post by: Johnwebley on October 10, 2020, 04:55:56 PM
Have you got the head off?
Or the cam off?
If not. That may be the reason it is  difficult to rotate.
The cam opening the valves
Post by: K2-K6 on October 10, 2020, 05:04:33 PM
If you want to lift the crank out you can remove cam and rockers to let the cam chain drop down to crank,  then undo conrods/ big ends and lift crank out
You dont have to disturb the barrels and head at this stage.
Post by: PJM47 on October 10, 2020, 05:43:25 PM
Cam and head still on. Haven’t touched the top end at all. I’m a bit reluctant to take things apart unless it’s really necessary, so was trying to establish what is normal and what is sensible to check for at this point.  The more I take apart the more I can check but also the more chance of things going wrong/me failing to put it back together properly :)
Is there any fairly non intrusive checks I can do? Would it be silly to put it back in the bike now?
Post by: Nurse Julie on October 10, 2020, 05:54:51 PM
No point in putting engine back in the frame yet, you haven't really diagnosed the problem yet. It would be such a shame and a pain to have to take it out again.
Post by: PJM47 on October 10, 2020, 06:12:39 PM
Yes absolutely, but do we know there actually is a problem now?
Post by: Phil Ward (RIP) on October 10, 2020, 06:56:09 PM
Been following this thread and all the experts views - I would go for a full strip (I know its not what you want to here) - I think hydraulic lock damage - piston/rod - needs to be eliminated
Post by: Bryanj on October 10, 2020, 07:19:12 PM
Sorry its got to come apart, there should be no difference 1&4 moving and 2&3 moving
Post by: SteveW on October 10, 2020, 07:21:36 PM
I don't know if this is even possible but could the cam have sheared in two?
So if only a part of the cam is turning you could get more than one compression stroke at a time and therefore way more difficult to turn engine?
As I said I don't know if this is even possible but a mate of mine did have a cam shear in two in his car once.
Post by: Bryanj on October 10, 2020, 07:26:28 PM
Yes its possible and yes it has happened on other bikes before
Post by: K2-K6 on October 10, 2020, 07:31:25 PM
Inspection of cam is easy,  just remove cover as it is just that "a cover" and disturbs nothing.
Post by: PJM47 on October 10, 2020, 07:57:54 PM
Ok will have a look at that next.
Post by: PJM47 on October 11, 2020, 09:33:16 AM
All looks ok under the rocker cover.
Cam out and head off next then. I'll read the manual, but any top tips I should be aware of?
[attach=1]
Post by: bobv7 on October 11, 2020, 09:40:09 AM
This thread started in August and it's now October and not a lot seems to have changed. WTF???? ::)
Post by: Johnwebley on October 11, 2020, 09:47:45 AM
Just take the cam out and see what happens.
It should be fairly easy to turn over.
Post by: Trigger on October 11, 2020, 09:56:16 AM
(Attachment Link)
I see a lot of damage were people put the wrong length bolts in the wrong place when putting the cam towers back on. There are 4 bolts that have number 7 on the head, make sure these go back were you took them from as, they are a tad longer than the other bolts and if in the wrong place will punch the bottom of the thread holes out and will leak.
What you need to do is remove the rockers and get the cam chain off. Leaving the cam towers on the head, place the cam shaft back in the towers and put the cam caps back on. Bolt it down and see if the cam rotates easy in the towers. This will rule out it the cam shaft is bent or not.
I still have not seen anything untowards from the pictures. Have you assembled the gear box in the lower casing and with the clutch basket on, tried the kick start ?
Post by: K2-K6 on October 11, 2020, 01:01:26 PM
Once you've removed the rocker shafts (and rockers) you can still turn the engine to see what it feels like ae all the valves are just left closed, as long as the plugs are out you'll not have any resistance from valve springs.
It obviously won't check the cam as trigger has indicated above though.
Post by: PJM47 on October 11, 2020, 04:45:44 PM
I've only just started stripping it down last week as I've been busy with other projects.
Post by: PJM47 on October 11, 2020, 04:52:38 PM
OK so rockers off, no change.
Cam out, no change.
Still very stiff to move in places.
Everything looks ok with the cam though.
Head coming off next then.
[attach=1]
Post by: Trigger on October 11, 2020, 06:01:54 PM
Cam out, no change.
(Attachment Link)
The cam chain is still on in your picture
Post by: PJM47 on October 11, 2020, 06:47:36 PM
Yeah I took it off, and the cam out after that pic. We’re only left with the con rods or piston rings. I guess.
Post by: Trigger on October 11, 2020, 07:14:29 PM
Did you test the cam in the towers with the chain off ?  You are jumping too far ahead with pictures so, if i can't see the stages then, i will miss things that maybe important to advise on this problem .
Post by: PJM47 on October 11, 2020, 07:25:31 PM
Yeah sorry I may have got carried way, I guess I thought as it felt the same with the cam off completely it wasn’t a cam problem.
Post by: K2-K6 on October 11, 2020, 07:39:21 PM
If it's tweaked the rods such that the big end sits out of plane with it's journal,  then that pinching would give sporadic resistance.
You'd expect to find witness marks on the big end shells as they would effectively try to wear "diagonally "  which if wearing away would slowly allow you to turn it as the shell material wears off.  Potentially  ;D
PJM47, notice, from dismantling, how you can set the cam timing with absolutely no risk when you come to reassemble as nothing interfears while rotating/ checking until you put the rockers in.  It's a very clever design like that.
Post by: PJM47 on October 12, 2020, 06:24:30 PM
So head off today. All went well, quite easy really. Barrels are all looking good, no marks or scoring.
Indeed this engine is beautifully designed, unlike the British ones from the same era I've worked on.
Still very hard and uneven to turn over as we would expect. So I guess fairly conclusive big end / conrod damage now as there's not much else left.
[attach=1]
Post by: royhall on October 12, 2020, 06:27:21 PM
Not necessarily, it may just be completely lacking in lubrication.
Post by: Phil Ward (RIP) on October 12, 2020, 06:33:56 PM
So final check is undo con rod main bearing and try manually moving piston up and down - if moves freely, then must be a tweaked rod. Logically, if you disconnect one at a time, and turn crank you will be able to identify which rod (rods) thats tweaked?
Post by: PJM47 on October 12, 2020, 07:00:58 PM
Ok sound like a plan, will do this next.
Post by: Trigger on October 12, 2020, 07:44:08 PM
It should of still turned the clutch basket with the kick.
Post by: PJM47 on October 12, 2020, 08:35:51 PM
Yes I think it probably would have turned if I tried hard enough but i didn’t want to go mad and break something else when it obviously wasn’t happy. it really really didn’t want to turn on the kick. It’s possible there’s more thank one problem of course but hopefully not. Also it is freeing up a bit from where this started when it wouldn,t turn on the crank either. Should find out soon enough thanks to all the encouragement to get on with it.
Post by: PJM47 on October 13, 2020, 05:18:06 PM
OK so hope you are all still interested in this the one folks. Think we are getting to the end. Not sure who is on for winning the sweepstake.
So I removed one rod at a time as suggested thinking at some point it would free up, but got to the last one and guess what, it is still exactly the same, it turns a bit then gets stuck. As everything is loose it now actually lifts the crank out of the case / bearings if I try to turn it more. The primary chain is off at this point and there is nothing left connected just the crank sat in its slot, it won't rotate freely.
It looks like the big gear behind the alternator is right up against the case and maybe getting stuck in places, its very close anyway. So bent crank or maybe just that gear is bent? Should it be so close to the case?
[attach=1]
[attach=2]
Post by: royhall on October 13, 2020, 05:25:43 PM
Just try oiling the shells they won't turn bone dry.
Post by: PJM47 on October 13, 2020, 05:27:51 PM
Yes they are all fully oiled
Post by: Trigger on October 13, 2020, 05:29:38 PM
The wheel on the flywheel does sit close. It is very hard to bend a 750 crank, are the crank case shells equally worn ?
Post by: MrDavo on October 13, 2020, 07:03:11 PM
Quote
I'll take bent crank please Eamon. I've bent a Triumph T140 crank, and they are positively agricultural in comparison. Amazing what hydraulic lock can do, its the irresistible force meeting the immovable object, but something has to give.
Post by: K2-K6 on October 13, 2020, 07:07:39 PM
It does sound like the crank is bent doesn't,  from the rotation description  :o
I'd not have guessed at that from the beginning.  On the positive side,  it shows how strong the rods and starter motor are  :D
Post by: allankelly1 on October 13, 2020, 07:10:41 PM
Yes if the crank is binding in it’s main bearing journals then it’s most likely bent but since the force was transmitted thru the rods surly you should call them suspect too?
Good luck
Best wishes Al
Post by: royhall on October 13, 2020, 07:12:21 PM
Not necessarily. The drag of bone dry shells could have moved them in the casings.
Post by: Trigger on October 13, 2020, 07:39:11 PM
Take the fly wheel off. Grease the shells , place the crank back in and bolt the cases together , then turn the crank by hand  ;)
Post by: PJM47 on October 13, 2020, 08:31:07 PM
Yes flywheel next. Doesn’t that need a special tool though? Any recommendations?
The wear on the shells is fairly even.
The flywheel gear is so close I can’t get my smallest feeler in between it and the case, that doesn’t sound right, and there are marks on the case where it looks to have rubbed.
Post by: MrDavo on October 13, 2020, 10:53:23 PM
That gear wheel that is fouling the case took all the torque from the starter motor, trying to turn a crank that was locked solid. Is it possible that it is just now on the p*ss somehow, and the crank isn’t bent? The way it is fouling and leaving a witness mark makes me wonder, the main bearing hasn’t moved laterally looking at the picture. I can’t see the gear wheel bending, but nothing is impossible.
Possibly the starter clutch arrangement is damaged or bent instead, that would be a far better outcome than the crank. I had a tool to get the alternator off but nothing would budge, I ended up going to a local engineering shop. Trigger’s yer man there, however if it is now on skewiff then things may not be straightforward.
Post by: K2-K6 on October 13, 2020, 11:10:32 PM
Still something odd there as the crankshaft should rotate forward while leaving the starter gear stationary via it's sprag clutch.
It may prevent the starter motor from operating,  if it were damaged.  But the kickstart doesn't go through that way,  it's via the primary drive direct to crank and avoiding the starter gear.
You'd have imagined that the kick would still work in the above scenario.
Also if main bearings where dry,  it's likely that it would be consistent in resistance for whole rotations,  and not more pulse like.
Post by: McCabe-Thiele (Ted) on October 13, 2020, 11:33:47 PM
That gear does look very close I'm not familiar with your engine but how is the gear & flywheel located on the crankshaft is it a woodruff key & taper fitting ?
Is there any kind of spacer or thrust washer between the gaer and the crankcase any end float control?
Post by: Bryanj on October 14, 2020, 12:21:59 AM
Generator is on a taper and there are no thrusts as there is no sideways force on the crank, unless you throw it down the road
Post by: McCabe-Thiele (Ted) on October 14, 2020, 10:15:03 AM
I'm thinking the woodruff key has moved as part of your troubles - I can't see the crank being bent given the circumstances. It's definitely a mystery it will be very interesting when you finally locate the cause.
Post by: Trigger on October 14, 2020, 11:27:35 AM
No woodruff key on a 750 SOHC  ;)
Post by: MrDavo on October 14, 2020, 12:13:12 PM
If the gear is on a taper then it could have shifted to 'cockeyed' under a twisting stress, especially if there is any scope to move sideways, even by a fraction.If it is now fouling the case then it would still be hard to turn even from the kickstart.
Whatever I am glad you are getting to the bottom  of it, as the suspense is killing us.
This reminds me of when, as a teenager, I worked some evenings and weekends at a garage in Lancaster - even at school I had a Moggie Minor and a Triumph T100 to support. One day the boss asked me to come with him to help tow in a Mini estate that had clanked to a sudden halt in Galgate. We spoke to the lady driver, who told us that she had just topped the water up at a petrol station, and how it had taken ever such a lot to fill it right to the top. My boss asked her to show him where she had put this water, and she pointed to the oil filler cap on top of the rocker cover.  :o
Post by: PJM47 on October 14, 2020, 01:19:33 PM
Thanks for your continuing support on this one people.
After lifting the crank in an out a few times the large starter gear has come loose and is now free to move on the taper shaft, I can move it latterly by 5mm or so, it spins freely (independently of the shaft) clockwise but not anticlockwise. Not sure what is going on there.
But with the starter gear now floating loose on the shaft and the crank back in the case, the crank now rotates freely and smoothly, phew, so I believe somehow that gear had got jammed against the case causing the problem.
I need to get the special generator puller tool before I can look any further, and how to fix it is not yet clear but I'm thinking we are pretty close now...
Paul
Post by: Trigger on October 14, 2020, 01:25:17 PM
On the inside of the starter cog is a bronze bush, it is easy to see it that is damaged  ;)
You have done this a little arse about face as, you should of taken the fly wheel off before splitting the engine  ::)
Post by: Phil Ward (RIP) on October 14, 2020, 01:29:51 PM
No problem with the starter riing only turning one way as that's what it should do - so one thing less to worry about
Post by: K2-K6 on October 14, 2020, 01:29:56 PM
"After lifting the crank in an out a few times the large starter gear has come loose and is now free to move on the taper shaft, I can move it latterly by 5mm or so, it spins freely (independently of the shaft) clockwise but not anticlockwise. Not sure what is going on there."
That's the correct operation of it,  a very clever "sprag" clutch that will spin the crank in one direction when actioned by the starter motor, but be completely free in rotation in the opposite direction.  It stays still while the motor runs and is virtually frictionless.
It means the starter doesn't have to be engaged/disengaged unlike a car system.
Post by: Phil Ward (RIP) on October 14, 2020, 01:33:34 PM
Will be difficult to get it off now even with the tool due to holding the crank - should be doable but more difficult
Post by: PJM47 on October 14, 2020, 03:44:39 PM
Ok learning a lot here.
Managed to get the generator nut off, just waiting for the puller tool now.
Although the starter gear is now behaving more correctly (it didn't spin any direction before, only just realised that wasn't normal!) I assume there is still something wrong? In normal operation is that cog free to move a bit latterly. I assume it's not meant to be able to rub the case if it wants?
Post by: Bryanj on October 14, 2020, 05:02:14 PM
Still doubt the starter gear caused the problem
Post by: K2-K6 on October 14, 2020, 05:39:22 PM
There's a sectioned schematic of it in the original 750 manual (doesn't appear in last one) that may help, check Ash's dropbox stash for a look.  If not there I can photo and post from mine.
Post by: Bryanj on October 14, 2020, 08:25:47 PM
The gear runs on the parallel bit of the crank, i have seen the clutch ass come loose on the back of the rotor but not often.
I think the owner might like to look at the job lot of 750 parts in another thread where at least one of those cranks sould be usable
Post by: PJM47 on October 15, 2020, 08:15:13 AM
Thanks, found the one in Ash's dropbox, much clearer.
Post by: PJM47 on October 15, 2020, 03:52:33 PM
Generator wheel and starter gear now removed. Can't see any problems with any of it. Only thing I'm not sure about is if the gear is meant to be able to move about a bit on the shaft.
So do just put it all back together now? Perhaps the starter gear was just seized up a bit from when there was no oil? It's all free now anyway.
I'll replace all the seals and gaskets, anything else worth replacing/checking whilst its apart? Nothing is in particularly bad condition, little bit of wear on some of the main bearings. I leak tested the valves and all seems good is it best to leave those alone?
Post by: paul G on October 15, 2020, 04:03:44 PM
I think that would be a false economy not replacing the bits that you can while you are in there.
Primary drive chains and cam chain if they need it.
Why would you want to tear it down again.
Lapping in the valves is a simple job and replacing the valve stem seals is a no brainer  :o they are in the gasket kit anyway.
Post by: Trigger on October 15, 2020, 05:37:05 PM
As PaulG has said, you are in there and you don't want to take it apart again as Paul G knows very well  ;)
Look at changing the primary chains, cam chain to a up graded FTH DID, all the o,rings, including oil pump and inspect the primary chain tensioner to see if it has gone hard and brittle, check the cam chain tensioner, mid wheel and cam blade for brittleness, cracks or chips. Check the piston rings are not suck in there groves and turn easy. I would throw another set of rings on to be on the safe side and they can be bought for around £40 for a full set. Always use a top quality gasket set and upgrade the O'rings that are in the kit.
Put the crank on a bench and put all the rods on in the correct order and the right way round, torque them up and make sure they turn on the crank very easy with no tight spots  ;)  Build up the bottom end first and test everything before even temping to put the top end on.
We like pictures so, loads of photos as you go and we can advise if something is not quite right.
Post by: PJM47 on October 16, 2020, 04:29:56 PM
ok thanks, will look at doing do all that.
Any recommendations as to a good gasket set and piston ring set? DS spares seems to be out of stock on both. There's a few on ebay but I've no idea of quality.
e.g.
https://www.ebay.co.uk/itm/Honda-CB750K-Four-1969-1978-Complete-Engine-Gasket-Seal-Rebuild-Kit/112709539389?hash=item1a3e03163d:g:SMcAAOSwN7pamvaM
https://www.ebay.co.uk/itm/Full-Gasket-Set-For-Honda-CB750F1-2-K1-7-SOHC-1970-1978/121817106884?hash=item1c5cdd89c4:g:H5MAAOSwrklU2js3
Post by: MrDavo on October 16, 2020, 04:50:57 PM
I used a Vesrah gasket set, everything was there and fit fine, but the genuine head gasket is far superior, and has a 'sticky' finish which the pattern ones don't.
Following advice on here, I got a genuine Honda head gasket from CMS, it cost more than the whole Vesrah set. Worth it for the peace of mind in my opinion, as has been said you only want to take the engine out once.
Post by: Trigger on October 16, 2020, 05:16:13 PM
The gasket sets in the link are no good for early 750K's. You will need Vesrah VG156/556 for a early engine and i am out of stock of those. Phone Sliver and ask when he will have Vesrah gaskets back in stock but, make sure it is VG156 as he was selling VG158 for the early engine which was wrong  :o
If you need seal kit, cam chains or any upgraded O'rings then, ask Nurse Julie.
For rings: These are cheap but they are Riken and i have fitted over a 100 sets of these >>> https://www.ebay.co.uk/itm/69-76-HONDA-CB750K-STANDARD-PISTON-RINGS-SET-4-RINGS-INCLUDE-11-CB750KPR/254040843680?hash=item3b2603a5a0:g:D0MAAOSwfQRXMPEZ
Post by: paul G on October 16, 2020, 07:45:25 PM
In my defence it wasn’t through skimping on parts :D all I can say is my engine came in a million parts and 5th gear fits both ways and only one is correct  :(
Post by: PJM47 on October 16, 2020, 08:13:28 PM
Thanks really helpful advice. I’ve ordered those piston rings and will look for the right gasket set.
I’ll go for cam chain as well so will need that and if there’s upgraded o rings that help sounds like a good idea.
Not sure if I need primary chains yet, they are quite expensive..
Post by: Phil Ward (RIP) on October 16, 2020, 08:30:24 PM
I know that the cost of the strip and find you have done is going up and up, but I always put the full cam chain train wheel/blade/etc as after almost 50 years, the material will be degraded - advice on here (which I have always taken) is use genuine Honda as after market stuff is of variable quality - plus upgraded DID chain from Julie. As for the primary chain, I always fit one - check the tensionar wheel for damage (once again 50 year old, blah, blah, blah!)
Bloody expensive these rebuilds
Post by: Trigger on October 17, 2020, 07:44:17 AM
primary  chains can be had at a good price, just not in this country. If you know anyone that does business trips to japan or is off on holiday to there but, can be pricy if you have them posted here >>> https://www.yamiya750.com/index.php?main_page=index&cPath=246_21_250_63
Post by: royhall on October 17, 2020, 07:23:01 PM
The good thing about the 750 engine is that nearly all the parts are readily available, but sometimes at a premium price.
Post by: PJM47 on October 19, 2020, 02:01:13 PM
so most bits on order now (ouch).
Without wanting to start too much of a debate what's the best / recommended sealant for the bottom end? I've seen other posts but not really a conclusion.
Post by: Nurse Julie on October 19, 2020, 02:03:30 PM
Honda Bond, 3 Bond , Yam Bond etc for crank case halves only. The lightest, lightest smear, so light, you can almost see through it.
Post by: McCabe-Thiele (Ted) on October 19, 2020, 03:34:12 PM
Having followed this post with interest I am none the wiser yet as to what the cause was - have I missed something?
Post by: PJM47 on October 19, 2020, 04:23:01 PM
No I'm not sure I am either. Like I say at the start of this page once the starter gear was removed everything freed up. Putting it back on and everything is still free, the crank spins nicely, even keeps turning on its own with a push, I could barely move it before. Putting the rods back on as Trigger suggested and it still all turns nicely.
As I say my only concern was I'm not sure if that gear is mean to be able to move latterly on the shaft a bit which it does now. I have nothing to compare it to and nothing looks wrong.
I'd have been much happier finding something broken but not sure what else can be done.
Post by: Bryanj on October 19, 2020, 04:30:29 PM
Put the alternator rotor on temporarily(i.e. bolt not tight) then see if it wobbles when crank is spun, i have seen the taper end bent
Post by: PJM47 on October 19, 2020, 05:17:37 PM
No wobble. Checked with fixed point on the case, not that accurate, but nothing obvious.
Post by: royhall on October 19, 2020, 05:24:33 PM
Like I mentioned at the start it was probably that the petrol washed every bit of lubrication out of the engine and made it impossible to turn. Now it's re-olied everything is fine. But ensure on reassembly that every single part is cleaned and oiled and carefully checked.
Post by: PJM47 on October 19, 2020, 05:30:45 PM
Note it was definitely the starter gear that was the problem, then crank was in and out several times and fully oiled and nothing else connected, it was just resting on the bottom shells but it still would not turn freely. On one of the occasions of taking the crank out the starter gear came loose a bit and then everything was instantly fine after that. Still seems very odd to me.
Post by: PJM47 on October 19, 2020, 05:35:22 PM
Thanks, blimey Honda bond 4 is reassuringly expensive isn't it. Don't want it leaking though.
Post by: Bryanj on October 19, 2020, 05:55:41 PM
Only thing i can think of is the bush in the big gear is worn and allowed the gear to cock sideways, could be worth checking play to crank.
Sold a nos one to the states last year!
Post by: royhall on October 19, 2020, 05:58:07 PM
Trying to turn a locked engine on the starter has probably knocked it out of line.
Title: Re: Engine full of fuel and seized up
Post by: PJM47 on October 19, 2020, 08:33:42 PM
I sssume that bush is not replaceable?
I wonder if the bush has pushed in/back slightly under the stress allowing the gear to move further up the shaft than normal and hitting the case and also getting stuck? On the plus side at least the gear can be replaced after the engine is back together.
First pic is mine, secon pic is a used one on eBay.
[attach=1]
[attach=2]
Post by: allankelly1 on October 19, 2020, 08:43:30 PM
Hi
Looks like a glacier bush to me
I have changed these on my RD350LC kick starter idler and the clutch centre bush so could be well worth while if it’s shot pressing it out and getting a size and asking a local bearing supplier if they could supply a new one
(https://uploads.tapatalk-cdn.com/20201019/df0b2ffa8da3a8d003aa010514332dd9.jpg)
As then the bush and gear would be as good as new
Post by: PJM47 on October 19, 2020, 10:15:11 PM
Hi
Interesting thanks. I will look into it.
Post by: Trigger on October 20, 2020, 12:23:26 AM
That bush looks ok. But, always worth measuring it up
Post by: royhall on October 20, 2020, 08:18:08 AM
Looks like you found the smoking gun then. The wheel should not have been stuck to the crank it should be free to rotate. Amazing what lack of oil does to an engine. It is free to slightly move on the boss and is fed by pressurised oil to the bush and to behind the wheel through a feed hole. Make sure everything is straight before reassembly as those starters on a good battery put out a lot of torque.
Post by: PJM47 on October 20, 2020, 07:18:42 PM
Yes hopefully that’s it. Evetthing else seems nice and straight and in good condition. Just waiting for all the bits to arrive. New cam and primary chains and tensioners. New seals everywhere new piston rings. And I’ll do the valve guide seals and lap. Should be a nice little overhaul for it anyway.
Do we think I need to give the cylinders a light hone to put cross hatching back to settle in the new rings or is best to leave as is?
Post by: Greg65 on October 21, 2020, 03:30:05 PM
A light deglaze with one of those glaze busters or a very light touch with a 600 grit honing tool should suffice. Seeing as the engine is split have you had the bores measured to check their in spec and don’t need a rebore and oversize piston? Hope I’m not creating more expense,
Cheers,
Greg
Post by: PJM47 on October 23, 2020, 02:52:54 PM
Can I measure the bores myself with the right equipment? I prefer to invest in tools and learning rather than get someone else to do things where possible. Visually the cylinders look in good shape though.
Post by: Bryanj on October 23, 2020, 04:15:56 PM
To do that you need a bore gauge and a 50 to 75 outside micrometer both can be got on ebay for about £30 each for chinese made ones, better ones, starret/mercer/moore and wright cost more
Post by: PJM47 on October 24, 2020, 03:30:45 PM
Ta, the bores are in good condition no sign of scoring or lips where the pistons end so should be ok but I will check anyway.
On to the main bearings, please could people advise on whether they think these should be replaced, I know not easy to tell from the pictures. Any help appreciated as always.
[attach=1]
[attach=2]
Post by: Bryanj on October 24, 2020, 04:06:51 PM
Worrying one to me is the near centre one in the top case which looks very scuffed, others look slightly scuffed but usable, personally although its not cheap i would replace them all you jest need to read the codes on the crank and crankcases.
Considering the marks on the mains i think its worth splitting the big ends and inspecting.
Its all work and more expense but these motors need doing right
Post by: PJM47 on October 24, 2020, 04:23:18 PM
yes what I thought. That centre one is the worst case and I will replace the pair. I was hoping to avoid having to replace them all though as they are so expensive, but maybe it's worth doing now. What seems like a no brainer job on this bike is always a hesitation as everything is so expensive.
If anyone has a source of bearings cheaper than £15 a shell that would be good :)
I think I have worked out the codes, BABBB on the case and AAAAA on the crank so I make that 4 greens and a yellow.
Big end bearings all look pretty good, much better than the mains.
Post by: paul G on October 25, 2020, 07:22:14 AM
I got mine from Yamiya, Cheaper than Silvers even with post and capture duties😉
Post by: McCabe-Thiele (Ted) on October 25, 2020, 07:52:20 AM
When I worked on petrol engines (mainy on cars admittedly)  it was pretty much routine that a crank removal led to replacing the crank & main shells. Even when the bearings didn't look that bad it was a case of well my labour is free so why skimp on the material costs bearing in mind the amount of effort involved in dismantling the engine again.
I also found that replacing piston rings under the same argument was not as effective unless there was a very good reason such as poor compression, visible damage such as a broken ring or piston lands plus of course bore scoring / excessive oil consumption.
Likewise I have never been a fan of glazebreakers after over doing it once resulting in needing a rebore. I would prefer to have a rebore if the aforementioned issues were found. I also learnt to my cost that there was a wide range of competency in machine shops that did rebores. In the 1970's there were something like 8 or 9 firms in the Derby area that carried out engine machine work. Some firms seemed to live on reputations that were not maintained over time.
If I have to have a rebore on my bike I would struggle to know anywhere locally as I am now out of the circle of local knowledge - I haven't had an engine rebore since 1979. Irrespective of the distance from me I would in all honesty place my trust in someone such as Trigger as he has what I perceive as that rare combination of reputation, skill, pride in his work with a love of what he does.
Post by: Bryanj on October 25, 2020, 09:39:41 AM
You are correct in that getting a decent rebore nowadays is difficult, probably due to the eliability of modern car engines compared to the old Vauxhaul and Ford units, hate to think how may Kent and Essex lumps i have rebuilt in my life and yes with cars not changing shells was a stupid idea but then a full set of Kent shells cost the same as 1 journal for a sohc 4, having said that i would not even consider replacing just one journal, it has to be a full set
Post by: Phil Ward (RIP) on October 25, 2020, 12:29:19 PM
Had a 1200 Anglia that had a 'rubber crank' - 3 main bearings - centre bearing always knackered (was that a Kent or Essex or none at all?)
Post by: taysidedragon on October 25, 2020, 12:47:59 PM
Same engine as a Ford Model T! 😁
I t-boned a Ford Anglia with my Bonneville in the seventies and the car came off worse. The paint was holding the bodywork together.
Post by: cliff7 on October 25, 2020, 01:09:31 PM
Kent engine. 1340 fitted to Consul Classic was even worse.
Post by: Bryanj on October 25, 2020, 02:45:08 PM
Early Kent, later they went 5 main brg. Essex was the big cast V4 and 6, now the V6 was one i could build blindfolded, would last forever if you changed the oil pump and drive shaft every 80,000
Post by: PJM47 on November 01, 2020, 03:05:59 PM
Bottom end ready to close up?
[attach=1]
[attach=2]
Just waiting new chain tensioner and an o ring for that front tube.
Post by: PJM47 on November 01, 2020, 03:11:50 PM
Not so keen on this. Looks like it has been hacked with a screwdriver by someone trying to open it. The top end has been off before. It was covered in sealant as well. Do we think this will seal ok with new gasket?
[attach=1]
[attach=2]
Post by: Bryanj on November 01, 2020, 03:36:17 PM
Seen worse run OK also seen better leak.
Make sure no raisedbits and try it
Post by: K2-K6 on November 01, 2020, 04:02:03 PM
I'd use something like Hylomar blue on both sides of the gasket for the above.
Talking about "selotape" coating level (from aerosol) to let dry before assembly and degrease faces with carb cleaner or isopropyl alcohol just prior to installing.
Post by: Trigger on November 01, 2020, 08:19:10 PM
(Attachment Link)
(Attachment Link)
Are you sure that those barrels have not been decked ? As i can see markings from a head skimming machine.
Post by: PJM47 on November 01, 2020, 09:54:29 PM
It’s possible it’s been worked before, certainly head has been off as there was a washer missing when I took it apart.
As long as we think it coukd be ok, may be with a bit of hylomar that’s a relief.
Post by: Bryanj on November 02, 2020, 08:51:51 AM
Should you try the Hylomar a BIT is the important part!!!!
Post by: PJM47 on November 02, 2020, 04:10:00 PM
Ok noted. Or do we think I am better off not using any sealant at all? Opinions vary.
Post by: Bryanj on November 02, 2020, 04:42:01 PM
Personalty I wouldn't as the damage is nowhere near he fire ring or an oilway
Post by: Trigger on November 02, 2020, 05:23:16 PM
It was sealed OK before you took it apart without anything. I would never use any sealant on any gaskets as, the 750 is prone to the oil jet blocking with sealant and bang goes the top end  ;)
What jets does the head have fitted ?
Post by: PJM47 on November 02, 2020, 05:45:55 PM
Not sure, is this the jet you mean:
[attach=1]
Post by: Bryanj on November 02, 2020, 06:58:25 PM
Thats the one, take it out and make sure the oilways are super clean, you should also fit 4 O rings, 2 at the jets and 2 in the blank recesses at other end of cam tower
Post by: K2-K6 on November 02, 2020, 07:20:18 PM
Yes,  there's one for each side of the head.
Purpose is to restrict the oil flow to designed rate while maintaining pressure within crankshaft supply architecture, the cam area being low pressure as opposed to the crankshaft being high.
It's the nature of any restriction in flow that it will "collect" any stray particals (it's only fed filtered oil) resulting in impaired flow or blocking.
The risk here is to have detached and excess sealant pass onward up from gasket face and get stuck in those small restrictions.
It's your appreciation of this as to the decision you make,  blocked they will certainly trash their onward valve train,  of that there's no doubt.
I've used Hylomar spray as stated above (light spray of gasket and leave to dry) to leave a "selotape" quantity fine film on the gasket.  This primarily on the F2 engine as they are very prone to oil seeping at the head gasket,  this never with any problems.
I can see the other point or view and wouldn't argue with the logic, but know that many owners fret about any oil leak at all here at this juncture. It's highly unlikely to compromise the compression sealing of the engine (with no sealant applied) so not a worry from competent running perspective.
Of course if it does leak it's just that normally and not drastic, versus the other risks.  But naturally it's engine out to correct.
Giving a clear picture hopefully will help
Post by: PJM47 on November 02, 2020, 08:26:24 PM
Ok thanks for the explanations. Makes sense. Probably safer to leave it dry.
Having had various old British bikes I’m not too concerned about oil leaks.
I will make sure those jets are clean before putting it back together.
Post by: Trigger on November 03, 2020, 02:20:42 PM
These should not leak if the studs are sealed and the O'rings are up graded  ;)
Post by: PJM47 on November 03, 2020, 06:37:08 PM
Are the o rings that come with the vesrah 156 any good? If not would you be able to point me at suitable upgraded ones please?
Post by: Nurse Julie on November 03, 2020, 08:17:29 PM
I have stock of all the upgraded O rings you need Paul. I will PM you after I've cooked dinner 😁😁😁
Post by: PJM47 on November 06, 2020, 10:33:54 AM
Trigger of you get a second would you be able to elaborate on what you mean studs are sealed? How would I do this? I have the upgraded O-rings now. Ta.
Post by: Nurse Julie on November 06, 2020, 12:32:29 PM
The head studs that can leak are the ones that the towers slide over and they have a  M6 washer and M6 nut. If the stud thread is not sealed with thread lock, oil can weep down the thread to the spark plug area.
Post by: PJM47 on November 06, 2020, 06:49:55 PM
OK thanks
Post by: PJM47 on November 17, 2020, 05:13:21 PM
Hi folks
I’m getting ready to put the engine back in, I thought first I’d hook up
the oil tank and try to see some oil flowing. But I am struggling to get pressure, I am turning it on the starter, as much as I dare not wanting to damage it, and all
looks good but I’m not seeing much or any oil get to the top end.
I’ve read this is not unusual with air locks in the pump. But I am not sure now whether to just put the engine back in the frame and sort it later or persevere with it on the bench. Opinions vary on what do.
I tried priming the pump but its not really possible with the engine vertical for access. I filled the oil gallery and that didn’t help, tilted it to the side, didn’t help.
Any thoughts appreciated.
Post by: MrDavo on November 17, 2020, 06:18:25 PM
After a complete failure to get any oil pressure in my CB750K1 engine after I rebuilt it, a worried query on here sent me off to Boots to buy a tub of generic Petroleum jelly (it doesn't have to be Vaseline by brand).
I took the oil pump apart and packed it with the stuff, then tried again. Instant success! Oil appeared in the oil gallery at last, then in the cambox. I believe some old American V8s use the Vaseline technique as a matter of course to get their oil pumps started. The jelly simply dissolves into the oil, and wont damage or block anything. One wonders if Honda did something similar at the factory, I recall reading that they came primed with some sort of fishy oil that had to be replaced before use, the ex Honda workshop guys on here may be able to confirm that.
There was also a very sad thread on here from a member who put all his effort and money into a rebuild, then started his CB750 up without checking for oil pressure. the result was a beautiful rebuilt bike with a freshly ruined motor.   :( As I remember it he was too disheartened to pull the engine to do it all again, and sold the bike 'as is' for someone else to fix.
Post by: Trigger on November 17, 2020, 06:42:09 PM
As Oddjob says, pack the pump.
You should not try to turn the engine on the starter motor until you have oil pressure up or you will damage the shells. Lets hope you put bearing guard on the shells when yo assembled the engine  ::)
Post by: allankelly1 on November 17, 2020, 06:52:07 PM
Yes packing the pump with Vaseline is standard practice when building Rover V8 engines so the pump can prime itself
Post by: K2-K6 on November 17, 2020, 07:48:24 PM
As already noted above,  vaseline method is good.
Also if you want to observe for initial flow,  the pump goes straight to the oil filter housing which you can look at without the filter on to see if you've any output at all. As soon as you can see it coming through that pipe you know the pump head is operating and filled with oil.
If present there, it will have to fill the housing then go through the filter to enter the feed galleries via the centre of the bolt.
If you take the oil filter housing off and it's dry,  then it confirms the pump is air locked.
Post by: PJM47 on November 17, 2020, 08:13:57 PM
Ok thanks, I did read about the vaseline truck but I wasn’t sure. Should I be able to get oil pressure or at least oil coming out the filter hole just turning it over on the starter? or am I better off waiting til I can fire it up properly.
Post by: K2-K6 on November 17, 2020, 08:29:31 PM
You won't get pressure,  but it's got to go thtough there first to get to the rest of the engine.
So if nothing comes out at all,  then you'll never get pressure anywhere.
You've literally got to see it delivered through there,  then that confirms the pump is pumping oil.  Put the filter assembly back on and it should then fill and deliver through the whole system.
Post by: PJM47 on November 17, 2020, 10:14:59 PM
Ok sounds like just a priming issue, I”ll put the engine back in the bike and then sort that, not much point doing it now and again when it’s fitted.
Ta
Post by: K2-K6 on November 17, 2020, 10:54:47 PM
Usually once the pump has oil all the way through it then it just picks up ok even if supply has been interrupted.
It's usually from empty pump and pipes to and from that it just won't suck.
Post by: K2-K6 on November 17, 2020, 10:59:05 PM
A fine engine, one of my favourites. Have you an interest in them?
Title: Engine full of fuel and seized up
Post by: allankelly1 on November 17, 2020, 11:35:16 PM
Yes
Built a Dax Rush with a 4l Rover V8 in
Engine built by myself and Dave Ellis and  as you can see was not in standard tune
(https://uploads.tapatalk-cdn.com/20201117/60279e5012d8fcc9e0cd3a9ca5c4d7de.jpg)
(https://uploads.tapatalk-cdn.com/20201117/b73cccebf3c50e0ef75adf5868d00339.jpg)
Car weighted in around 650kg as a total kerbside weight as due to the the Rover being an all aluminium block and heads the engine only  weights in at only 212 kg for a 4L lump (around the same weight as a Ford 2L pinto) so nice power to weight ratio
Fun but needed to be respected as it could bite you in the arse in a blink of an eye
Post by: McCabe-Thiele (Ted) on November 18, 2020, 08:07:29 AM
That's a Beast of a motor !
Back in the late 1970's a good friend of mine fitted his Ford Granada Mk1 with a Holley 4 barrel Carburetor fully upgraded rover V8 engine after extensive changes to the bulkhead plus fitting a Jaguar (IRS) rear axle.
It was a beast to drive and a tad happy at the back end especially in the wet.
Post by: Phil Ward (RIP) on November 18, 2020, 08:40:09 AM
That's one lovely looking, well engineered car! Always preferred the looks of the Dax over the other Lotus 7 styled cars
Post by: allankelly1 on November 18, 2020, 10:45:16 AM
Yes
Always loved  the more purposeful look of the Dax Rush
Took some time to build and started with the engine first which took a year to build and cost in excess of 6k by itself as it was built on a brand new short block and it had lots of one off bespoke parts made by myself like  the thermostat housing and a one off pulley set
Then once engine / box was built then bought the kit and again spent again a small fortune
(https://uploads.tapatalk-cdn.com/20201118/5563927ece5b7ffbaa58a6653ea56227.jpg)
(https://uploads.tapatalk-cdn.com/20201118/f5c8938eec22d4dda0a9266d271d589e.jpg)
(https://uploads.tapatalk-cdn.com/20201118/00de0c8933c30bbbbe13b2bfa630565e.jpg)
(https://uploads.tapatalk-cdn.com/20201118/7d6e5e8c0b4f191cdf0c08c5ad873fa4.jpg)
Was sorry to see her go and had a tear in my eye but replaced the empty space in the garage with motorbikes instead as you got to have something to tinker with
Post by: PJM47 on November 18, 2020, 05:25:02 PM
That looks excellent.
I took the oil filter off and oil soon started coming out. Put it back on and within a few seconds oil came out at the top end and then all over my bench and the floor as I hadn’t noticed it was working. Not sure whether taking oil filter out and back in helped or just coincidence but it’s working now so all good.
Post by: K2-K6 on November 18, 2020, 09:46:22 PM
Good news then  :) it's always a little concerning and nervous time if you don't see it coming up as expected.
The bleed through, I suppose it's logical in that the system when closed with filter housing in place will run at 60psi with oil in it. So resistance to pumping the oil supply against air pressure may be just sufficient enough to prevent the oil filling the pump head (classic air lock) with the pump unable to draw oil through by trying to pump air,  if that makes sense.
In reality,  with the filter off and if the oil was warmer it would in all probability nearly run through there under gravity.
Nevertheless, it's the earliest point you can check for oil pump output to see if it's really pumping anything,  and easy to do to. As you found,  once the pump is going the rest will fill quite quickly.
Post by: PJM47 on November 18, 2020, 10:02:45 PM
Yeah makes sense, might be worth noting as a possible trick if anyone is having trouble in the future, especially as it’s an easy thing to try.
Post by: PJM47 on November 28, 2020, 05:29:32 PM
Just to finish this one off, engine is back in and running beautifully! Sounds really good, think it needed an overhaul anyway.
I replaced all the carb float needles and seats and overflow pipes to fix the original problem.
Many thanks for everyone’s help along the way.
Paul
Post by: Johnwebley on November 28, 2020, 06:09:16 PM
Best wishes. Glad it turned out.
Enjoy it when you can
Post by: Laverda Dave on November 28, 2020, 07:55:42 PM
Great news. It's been a good thread to read, you have a sweet running engine and we have all learnt a lot. Well done.
Post by: Phil Ward (RIP) on November 28, 2020, 09:10:42 PM
Paul
Good to hear its sorted Paul
Post by: royhall on November 28, 2020, 09:24:29 PM
Nice one. Glad to hear it's a sweet runner now. Don't forget to turn the petrol off.
