SOHC.co.uk Forums => CB750 => Topic started by: leadnavel on October 12, 2020, 05:56:47 PM
Title: Swinging Arm Bush appears to be a non standard size, why?
Post by: leadnavel on October 12, 2020, 05:56:47 PM
I’m a good way through my 750 K7 rebuild and thought that I would replace the bushes for the swinging arm as the end of one of the existing units are a bit knarled (image attached), here’s the problem, the replacement bushes from CMS (part number:52108-457-300) measure up different from my existing bushes! The inside diameter of the new bushes measure 21.80mm, the inside diameter of the old bushes measure between 21.39-21.40mm. In short the new bushes have a larger inside diameter than the old ones, so it’s defo not a ware issue!
I have questioned the part with CMS and they assure me that the correct part has been sent for the K7. I have also measured my existing Center Collar which measures between 21.34-21.38mm at the bush ends. I’ve had the bike since 1983 with very few modifications to it and she’s been off the road since 1986 (27’000 miles on the clock) so very few parts are worn. Does anyone know what’s going on here? Luckily I haven't taken out the old bushes as I would've been right up dump dyke!
Title: Re: Swinging Arm Bush appears to be a non standard size, why?
Post by: Nurse Julie on October 12, 2020, 06:03:37 PM
Are the ones you received from CMS the original plastic type or the bronze bush replacement type?
Post by: Nurse Julie on October 12, 2020, 06:20:50 PM
Just measured the ID of the bronze Bushes I sell for the 750/4's and its 21.40mm.
Post by: leadnavel on October 12, 2020, 10:23:25 PM
Thank you for your reply Nurse Julie, the parts that I got from CMS are of the plastic type. Can you shed any light as to why my bushes differ from the parts that CMS say are the correct replacements for my K7?
Post by: Nurse Julie on October 12, 2020, 10:38:16 PM
Absolutely no idea. What I do know is that the bronze bushes I sell fit the complete CB SOHC/4 range of bikes, including all the 750's K0-K8 and F1/ F2.
Looking at what I can see in your photo, is yours a standard swing arm?
Post by: Nurse Julie on October 12, 2020, 10:43:35 PM
One other thing, I've just measure the ID of a set of the OEM plastic bushes and they also measure 21.40 ID.
Post by: Tomb on October 13, 2020, 08:33:52 AM
The OEM type being plastic, and presumably a tight fit in the swing arm, would they not have a much bigger outside diameter, and crush somewhat when fitted? this may bring the ID down in size when fitted. Julies bronze bushes will not do this much therefore need to be "size" before being fitted.
Just a thought.
Post by: Trigger on October 13, 2020, 11:05:21 AM
Nope, still 21.40 when oem plastic bushes are fitted  ;)
Post by: leadnavel on October 13, 2020, 11:40:31 AM
As far as i'm aware my swinging arm is of the standard variety, what do think, is it? (image attached)
Post by: Nurse Julie on October 13, 2020, 11:45:24 AM
Yes, it looks to be, it was all the chrome that threw me of track.
So really, even though CMS insist the bushes they have sent you are correct, they are obviously not. I'm wondering if they are using a superseded part and although the OD may be correct, the ID is incorrect.
Post by: leadnavel on October 13, 2020, 11:45:54 AM
Just a thought.
The plastic material that the bushes are made from seems too stiff/brittle to be crushed down at all Tomb.
Post by: leadnavel on October 13, 2020, 11:50:31 AM
Thanks for your help guys. I have asked CMS for a refund on the parts but I have had no response, it seems to have fallen on deaf ears!
Post by: Nurse Julie on October 13, 2020, 12:28:08 PM
Oh dear 😕😕😕 I would be good to have an explanation from CMS how they sell them for that model but they don't fit 🤔🤔🤔
Post by: leadnavel on October 19, 2020, 11:55:25 AM
Just an update for you chaps... I contacted Dave Silver Spares who were very helpful and removed a bush from a sealed Honda factory package (52108457300 bush) and checked the I/D, they also say that the I/D is 21.80mm?! After reading some other posts on here, and the other place, I remeasured my Coller using a micrometer rather than a vernier gauge, the measurements come back pretty sound (no ovality) on both bush ends. Between 21.40-21.43mm. There's definitely something strange going on here!
Post by: Bryanj on October 19, 2020, 12:21:35 PM
Being as its plastic it may close up enough but you would have to fit it to check, have you measured the od of the bush and id of the arm?
Post by: Nurse Julie on October 19, 2020, 12:31:34 PM
Yep, definitely something weird going on. I'm working on the assumption that both Sliver and CMS get their stock from the same supplier and are incorrect 🤔🤔🤔
Post by: leadnavel on October 20, 2020, 11:29:23 AM
I'm not able to check I/D of the arm Bryanj as me, being of the cautious persuasion, didn't want to remove the old bushes before I had a chance to check the new ones for size. Just as well as it turns out, at least now I can rebuild using the old bushes/coller. It was a 50/50 call whether to replace the bushes.
Post by: steff750 on October 20, 2020, 05:41:46 PM
 ;) hi  why not bite the bullet and buy brass bushes (off julie) at least you know they fit and to be honest the plastic bushes are crap i never ever felt safe with them ive changed loads over the years and never put plastic bushes back in
Post by: leadnavel on October 27, 2020, 05:34:14 PM
My apologies are due to CMS as they have refunded me for the bushes, although they still insisted that they were the correct part.
Post by: Erny on October 27, 2020, 10:44:21 PM
I had the same issue year ago (Julie remembers well) - too big ID - mine were 21.7, they had free play on new collar. After I ordered new from producer all was OK
Post by: leadnavel on October 28, 2020, 08:19:30 AM
Interesting Erny, which producer did you get parts from?
Post by: Nurse Julie on October 28, 2020, 09:22:39 AM
Yes I do remember that Erny, where did you get the ones that were the incorrect size, was that CMSNL as well?
Post by: Erny on October 28, 2020, 09:45:49 AM
I got them (new set) from James, with bike I bought from him. Maybe he had them from you?
Attached pic of bushes box
Post by: Nurse Julie on October 28, 2020, 09:59:10 AM
No Erny, James didn't get those from me. I have supplied James and lots of other forum members with sets of Bronze Bushes and they fitted them with no problems that I have heard of. We have also fitted the ones I supply to all our own SOHC/4's and they are a perfect fit every time.
I can't remember how many sets I have sold on ebay and through Facebook sites but it's getting somewhere near 200 sets and maybe more with only good feedback.
Post by: Bryanj on October 28, 2020, 10:07:27 PM
That box says cb750/900 so i suspect twin cam
Post by: Nurse Julie on October 28, 2020, 10:11:02 PM
They are all the same part number Bryan so fit all the CB SOHC/4 models as well. My supplier also has them labeled as CB750/900 and they are the ones I have sent you before.
Post by: Bryanj on October 28, 2020, 11:04:23 PM
Didnt look that close Julie, i was on a 15min break before
