SOHC.co.uk Forums => CB500/550 => Topic started by: Topcat on October 19, 2020, 03:01:20 PM
Title: CB550 Bottom and top end rebuild
Post by: Topcat on October 19, 2020, 03:01:20 PM
Hi all,
Been a long long time since I checked in. Actually a fairly long time since I've had any time to work on the the 550. Thought I'd give you all a quick run through of what I've been up to, it's taken me so long to get round to this as I've had a bunch of other projects taking up time, including some building work that ended up causing problems (and a lot of time and money to fix).
However in the odd 5 or 10 mins I've had spare I've gone through the following on the cb550 engine.
Stripped down the engine back to cases and inspected all the internals.
Cleaned and rebuilt the bottom end and top end including replacing all bearings seals o rings, chains pistons etc
Where I am up to now is installed the rocker cover (freshly assembled new arms and shafts) to the head using the elastic band trick to hold the arms off the valve stems (don't really want to bend anything at this point).
At this point I'm just waiting on some new bolts for the rocker cover and need to source a L hand stamped plate and some soft washers that sit underneath. Does anyone have a plate and/or set of washers (think they are aluminium) they'd be willing to sell?
I can turn the motor over using the kick starter and can feel the pressure building up so once the cover is installed I'll do a compression check and leak down just to make sure everything is nice and sealed.
Finally my two big concerns at the moment is the cam chain tensioner seems not to have much in the way of free play in it. I'm assuming this is because the chain is brand new and will give a bit over time but can anyone confirm how much tension should there be on a brand new chain? (I've gone through the chain tensioning procedure where you move the 1-4 TDC then 15 degrees on (or where the spring attaches) before adjusting but it seems there is very little or no slack.
And finally the oil pump has a chunk out of the casing on the external side of where the o ring sits. I'm hoping this will still give a good seal under pressure but I may need to replace the pump if not.
Adding a few pics if it'll let me.
Topcat
Title: Re: CB550 Bottom and top end rebuild
Post by: Bryanj on October 19, 2020, 03:18:01 PM
New camchain is usually very tight so not much movement on tensioner, for soft washers use 6mm "Dowty" washers(alloy with rubber insert) but fit them carefully, as to the bracket i am afraid you will have to keep scouring ebay till one comes up, i actual have right hand but not left
Post by: Nurse Julie on October 19, 2020, 03:40:19 PM
Thats looking great.
If you give me the Part number of the  bracket i will look on my stock list for one .
Post by: Trigger on October 19, 2020, 04:52:39 PM
They are strange elastic bands holding up the rockers, they look more like the silicone 0'rings that seal the liners  ::)
Post by: Topcat on October 19, 2020, 06:07:06 PM
Haha yeah they are some strange ones, only ones I had on hand but have since bought a big box of proper elastic bands for all future bike building uses :D
Topcat
Post by: Nurse Julie on October 19, 2020, 06:14:34 PM
Topcat
I like them in green. Were they not meant to be fitted to the bottom of the liners before you fitted the barrels 🤔🤔🤔
Post by: Bryanj on October 19, 2020, 08:06:25 PM
Julie i think the left part number is 12336323000
Post by: Topcat on October 24, 2020, 09:35:40 PM
Hi Julie,
Sorry for not responding sooner had a bit of an annoying time with the bike (will explain later quite funny not its resolved though).
Part number is 12336323000
Topcat
Post by: Topcat on October 24, 2020, 09:44:03 PM
So I buttoned up the the engine and decided to do valve clearances and compression check while I'm looking for the plate part.
So hooked up the solenoid battery and got the starter turning over. Got the compression checker out and to my dismay all four cylinders were running at 60psi  >:( I really didn't understand this as looking at the cloud of oil and air coming out of exhaust side there was I was sure more pressure.
However I went back and checked all the clearances and tried again same result.
At this point I remembered my had given me a lot of his old tools so went searching and found another compression checker all four cylinders reading 160-170 psi.
So tomorrow I'll be burning the cheap sealey compression checker. But I've learnt a good lesson.
Topcat
Post by: Erny on October 24, 2020, 11:41:02 PM
Do you have carbs mounted? If so, you have to open them fully, incl choke to reach max psi
Post by: Nurse Julie on October 25, 2020, 07:51:36 AM
Hi Julie,
Topcat
Hi Topcat, sorry, we have 3 of the right hand ones but none of the left side.
Post by: Topcat on October 25, 2020, 01:45:37 PM
Nope no carbs at all, but as mentioned i think it was a dodgy compression gauge. I'm pretty happy with 165-170psi cold :)
Post by: Topcat on October 25, 2020, 01:48:16 PM
So I've been trying to run the engine on the starter and checking the oil pressure. Couple of quick questions
1. Is the starter generally enough to build up pressure to trigger the oil pressure switch? I've wired it up on a test light and it's not switching off and I'm nervous about running the starter any longer than I have at the moment.
2. What's the best way to check the oil is making it to the head?
Just want to be 100% sure before trying to fire up the engine properly.
Topcat
Post by: Nurse Julie on October 25, 2020, 01:57:32 PM
Take a tappet cap off of each end and look for oil spray from the spray bars, when the engine is running.
Post by: Topcat on October 25, 2020, 06:26:46 PM
Does the engine need to be running or should the starter be able to get the oil to the rockers?
Topcat
Post by: K2-K6 on October 25, 2020, 06:37:20 PM
Ordinarily it should get oil light out on starter,  but it can take longer than feels comfortable when going from an "empty" rebuild.
Not so sure you'd see that much out of rockers just while cranking it, it's probably doing about 250 rpm max so quite different from running with tickover oil pump volume wise.
Think Julie meant "running" to observe through rocker caps, I'll gracefully be corrected if not  :)
Presume you still have plugs out and some light oil in the bores?
Post by: Charlie J on October 25, 2020, 08:59:05 PM
Hi Julie,
Topcat
If you’re still looking for Part number 12336323000, Predator Motor Sport have 6 available
https://predatormotorsport.co.uk/PLATE-B-HEAD-SIDE-CB500K2-FOUR/
Charlie
Post by: Topcat on October 26, 2020, 06:49:21 PM
Yeah running plugs out  and some oil in the bores, until I'm sure oil is getting to the top end I squirt a bit in the bores before doing anything. I'll check all the levels to make sure its right before doing any running, had a bit of an oil leak where i forgot to tighten the oil drain plug. Looked up the torque values on the drain plug but didn't trust them not to strip the threads so hadn't even bothered hand tightening it :D
Can anyone advise a suitable torque for the drain plug not to cause damage (other than hand tight)?
Topcat
Post by: Topcat on October 29, 2020, 08:17:15 AM
Hi Julie,
Topcat
Charlie
Thanks Charlie I managed to pick one up from predator so all fitted now!
Topcat
