SOHC.co.uk Forums => CB350/400 => Topic started by: SeanFD on November 03, 2020, 12:09:07 PM
Title: Hondabond for oil pump/crankcase joint?
Post by: SeanFD on November 03, 2020, 12:09:07 PM
When reinstalling the oil pump, is it necessary or advisable to use Hondabons or other sealant on the mating surfaces?
I haven’t seen anything to the contrary so I’m assuming that the torque on the bolts is the standard ones for M6 and M8 bolts.
Title: Re: Hondabond for oil pump/crankcase joint?
Post by: Trigger on November 03, 2020, 12:19:16 PM
If it has a new o'ring that will seal  ;)
Post by: SeanFD on November 03, 2020, 12:32:57 PM
Thanks Trigger.
It does indeed have a new o-ring, so I’ll just tighten it up.
