SOHC.co.uk Forums => CB500/550 => Topic started by: Ibby4585 on November 24, 2020, 04:56:06 PM
Title: Honda cb550k1 throttle cables with uk bars
Post by: Ibby4585 on November 24, 2020, 04:56:06 PM
Could anyone tell me a source to get correct cables for my project that don't cost the earth. Cmsnl want £33 for pull and £28 for a pull cable. Silvers only has a pull cable in stock and I've just bought a set on Ebay listed for a 550 and they are incorrect.
Any info would be great.
I'm in the UK.
Kris
Title: Re: Honda cb550k1 throttle cables with uk bars
Post by: Johnwebley on November 24, 2020, 05:42:00 PM
Check out Wemoto.
Just locked and they have some
Compatibles
Post by: Ibby4585 on November 24, 2020, 06:46:51 PM
The ones that I bought are from wemoto.
Would the cables from a cb500k0 73' fit they are in stock at Silvers?
Kris
Post by: Erny on November 24, 2020, 06:48:21 PM
I'm in the UK.
Kris
I had the same issue - ordered ones from 4into1 (us). But they does not fit properly, wrong length of cable vs sleeve (bowden). Finally got used old ones from CB550F that fits perfect
Post by: Ibby4585 on November 24, 2020, 07:04:27 PM
Will have a hunt about.
Thats my exact problem, the inner cable  length is too long.
Kris
Post by: Ibby4585 on November 24, 2020, 07:30:33 PM
Cheers Oddjob, that would make sense i may take a punt on some 550f ones then from Silvers.
Post by: Ibby4585 on November 24, 2020, 07:35:27 PM
Silvers have both 550f1 supersport do they run the same carbs?
Post by: Phil Ward (RIP) on November 24, 2020, 07:35:44 PM
What about having the cable shortened? - https://www.carrotcycles.co.uk/custom-made-cables.html - probably expensive
or Wemoto - https://www.wemoto.com/bikes/honda/cb_500_(four)_k2/73 - think they give dimensions on the item discription
Post by: Johnwebley on November 24, 2020, 08:08:03 PM
I checked the 500.
At Wemoto.
You need to send them back with an explanatory letter
