SOHC.co.uk Forums => CB750 => Topic started by: Grumpyfck on December 14, 2020, 04:05:30 PM
Title: Wiring
Post by: Grumpyfck on December 14, 2020, 04:05:30 PM
Wiring idiot here, starter switch has RY + B, diagram says RY + RG.
Am I right in thinking B connects into RG?
Title: Re: Wiring
Post by: Bryanj on December 14, 2020, 05:02:47 PM
1 thats not the starter seitch its the sarter solenoid
2 need to know the colours of wires into the starter switch or button inside the LH handlebar switch
Title: Re: Wiring
Post by: MrDavo on December 14, 2020, 05:51:46 PM
That brew looks tempting.
Title: Re: Wiring
Post by: Grumpyfck on December 14, 2020, 06:07:49 PM
I will need to check that, I have an unaccounted RG right by  it, hence the mental jump. Apologies for the miss naming, I  read starter magnetic switch on the diagram.
Title: Re: Wiring
Post by: Grumpyfck on December 14, 2020, 06:09:48 PM
Never one to far away.
Title: Re: Wiring
Post by: Grumpyfck on December 14, 2020, 06:15:02 PM
I replied to the wrong post 🙄. They called it a starter magnetic switch on the diagram, I have a spare RG right by it so made a mental jump. With check the switch assembly.
Title: Re: Wiring
Post by: Bryanj on December 14, 2020, 07:38:40 PM
Bit more time now waiting for a muppet to unload 26 pallets.
The early bikes have power to the solenoid which is earthed by the yel/red at the handlebars
Later bikes have 2 wires to the button one black(12v with ignition on) and the yellow red which puts power to the solenoid when button pushed, more complex with US always on lights as at same time it dissconnects lights. This type then earths via the starter safety circuit(neutral light on OR clutch pulled in) the solenoid still has only 2 wires on it and it dont matter which way they go BUT you need to know which you have to avoid shorts
Title: Re: Wiring
Post by: Grumpyfck on December 14, 2020, 09:10:41 PM
Thanks, I am pretty rubbish at understanding electrics but trying to learn.  The posts were easy enough to follow by the book. Yellow red has what seems to me a straight forward connection.  The black wire was just cut as you see it with no clear connection. (F2 btw) having a RG right there with no apparent use was distracting. I will endeavour to investigate further.
Title: Re: Wiring
Post by: Bryanj on December 14, 2020, 09:23:17 PM
It is distinctly possible somebody has fitted an early solenoid to your F2 put a test light between the yellow/red and green/red on the loom and see if it lights up with ign on and in neutral, if so thats where you plug the solenoid.
10 min test if in front of me, impossible over the net!!!
Title: Re: Wiring
Post by: Grumpyfck on December 14, 2020, 10:43:44 PM
I can do that,  cheers. All learning isn't it.
Title: Re: Wiring
Post by: Grumpyfck on December 20, 2020, 11:43:48 PM
Well I connected the Black to the Red/green, with a little rattling I got the engine to spin on the button! Yay, success. That's most of the electrics figured out, just a few oddities to figure out.
