SOHC.co.uk Forums => CB500/550 => Topic started by: Sesman on January 10, 2021, 10:46:32 AM
Title: It’s arrived. At least most of it has...
Post by: Sesman on January 10, 2021, 10:46:32 AM
Just thought I’d share some January misery and ‘show case’ my classic HOS.
Julie, I’ll be in touch shortly if and when I can extract those carbs.
Happy New Year to all.
Title: Re: It’s arrived. At least most of it has...
Post by: Sesman on January 10, 2021, 10:50:14 AM
How do I attach multiple pics?
Post by: Sesman on January 10, 2021, 10:51:58 AM
Last one
Post by: Sesman on January 10, 2021, 12:55:38 PM
35 year old fuel :(
Post by: Rob62 on January 10, 2021, 01:06:38 PM
Looks like a nice project.... usa import?
Post by: K2-K6 on January 10, 2021, 01:55:32 PM
Looks like good project,  exciting to get something new to work on isn't it.
You'll have your work cut out with that old gummy fuel residue.
Post by: cooleronthecoast on January 10, 2021, 02:23:45 PM
Good luck with the project Phil.  I see in one of the photos you have a bottle of fizz on the garage floor available for when things start to get annoying?
 Excellent planning mate!
Post by: Sesman on January 10, 2021, 03:49:26 PM
That was the second bottle.... ;)
Yes, a US import with Title deeds.
Carbs are indeed going to be tough. I can’t extract any of the jets or float pins. The set is currently resting nicely in a bath of carb cleaner.
Post by: JamesH on January 10, 2021, 06:39:32 PM
Do yourself a favour - get a 5L can of pure acetone from one of the many suppliers on eBay. That used with a stiff paint brush will def help get rid of the gunge. It’s the only thing I’ve found that will effectively shift it. You can also soak the float bowls in it...
https://www.ebay.co.uk/itm/232379169006
Post by: Sesman on January 10, 2021, 07:41:56 PM
Thanks, James H...will do.
Post by: deltarider on January 10, 2021, 09:23:47 PM
But do it in open air!
Post by: JamesH on January 10, 2021, 09:40:11 PM
Lol
Obviously. And wear gloves (unless you want your nail varnish to be easily removed).
Post by: Sesman on January 10, 2021, 09:47:02 PM
Nail varnish...who’s been gossiping  :o
Post by: McCabe-Thiele (Ted) on January 10, 2021, 09:54:19 PM
I found fresh petrol is as effective as Acetone but it does take a little longer to work. Three out of the four carbs on my 400/4 were seized solid. Most of the sliders came free after 24 hours or less - one took a couple of days. I just sealed them in a Tupperware Box with some new petrol - if it looked dirty I changed it for fresh.
Post by: AshimotoK0 on January 10, 2021, 11:13:06 PM
The pro's use Methylene Chloride but of course that's pretty nasty so not readily available these days.
Post by: Sesman on January 11, 2021, 08:37:35 AM
Thanks everybody, I’ll try petrol first then move on if it doesn’t succeed. The slow/idle jet has already disintegrated in one carb, so taking it slowly from this point on. All other aspects of the carbs are in great nick, accept for the link bar, which is very corroded.
Post by: Charlie J on January 17, 2021, 10:13:38 AM
You can still get your hands on methylene chloride (dichloromethane) but have to declare it's for professional use.
https://www.apcpure.com/product/dichloromethane-99-9-acs/?attribute_pack-size=500ml&gclid=Cj0KCQiA3Y-ABhCnARIsAKYDH7t2EzaPAM5O6J9QnItEPTtwH3en0prFZYGOi0k1V9WIVvlPETUAQawaAhLVEALw_wcB
Post by: cantarauk on January 17, 2021, 10:43:43 AM
Seaman - same for me with the link bar. I have two sets of carbs with both having badly worn and corroded link bar. Not sure how I will get these sorted yet but any ideas welcome
Post by: Sesman on January 17, 2021, 06:32:32 PM
Hi, Cantarauk.
If I can work out how to separate the bar from the hinge posts I’ll polish the feck out of it then have if zinced. Failing that I’ll get my hands on some s/s bar and take it from there.
Just need some tips on dismantling.
P
Post by: Trigger on January 17, 2021, 06:57:46 PM
The shaft is hard chrome . I have put pictures on this forum loads of times on how to remove  ;)
Post by: Sesman on January 17, 2021, 07:02:33 PM
Thanks, Oddjob.
The end float was suggesting as much, but thanks for the insight. I’ll have a pop tomorrow. 7 days soaking in petrol and still no sign of the float pins moving...will engage in some autopunch action tomorrow with a post spacer and wire support to prevent the posts breaking...maybe.
P
Post by: Sesman on January 20, 2021, 05:07:07 PM
Apologies, Tigger. Just noticed your Jan 17 post.
I’ve done a number of searches using various clues, but haven’t come up with your photos. Could you send me to the relevant item please.
Thanks in anticipation.
P
Post by: AshimotoK0 on January 20, 2021, 06:28:02 PM
P
The Wonderful thing about Tigger  ;D ;D
https://www.youtube.com/watch?v=VurBc_QpUbs
Post by: Sesman on January 20, 2021, 07:59:29 PM
Oops, Trigger...  :)
Post by: Trigger on January 20, 2021, 08:03:24 PM
Oops, Trigger...  :)
Link >>> http://www.sohc.co.uk/index.php/topic,24343.msg220773.html#msg220773
Post by: Sesman on January 20, 2021, 08:42:57 PM
Thanks, much appreciated.
Post by: Sesman on February 11, 2021, 03:39:49 PM
From this to this. 25 mins at 55degs in Ultrasonic bath using 30% concentration of Allendales’ best brew. Also the stubborn float pins virtually fell out!
Thanks to Ashimoto and Charlie J et al.
Post by: Sesman on February 11, 2021, 06:21:01 PM
Thanks for the tip. All sound...phew.
Post by: Sesman on February 13, 2021, 09:07:00 PM
Not too displeased with the outturn as a first timer.
Thanks for the tips
P
Post by: McCabe-Thiele (Ted) on February 13, 2021, 09:12:46 PM
Looking good!
Post by: Nurse Julie on February 13, 2021, 09:14:53 PM
Great work.
Post by: Sesman on February 13, 2021, 09:23:07 PM
Cheers, bit of finessing to do then looking forward to them pi££#ng fuel over the engine paint job!
Where can I buy a single main jet o ring? I clumsily tore one.
Post by: Nurse Julie on February 13, 2021, 09:30:39 PM
I will send you one on Monday Phil.
Post by: Sesman on February 13, 2021, 09:38:53 PM
Wow, wasn’t expecting that, but very much appreciated. Will reimburse accordingly.
Oh, and carb finishing stuff I purchased from you...O rings, new screws an all. Makes the difference I think.
Also, s/arm bushes have arrived and have been  fitted. I thought the originals were fine... I was wrong. All good now, though.
Cheers Julie.
