Other Stuff => Misc / Open => Topic started by: Nurse Julie on January 16, 2021, 03:20:39 PM
Title: Change of MOT regs
Post by: Nurse Julie on January 16, 2021, 03:20:39 PM
I have absolutely no idea if this affect any of our old bikes, even though they are MOT exempt 🤔🤔🤔
[attachimg=1]
Title: Re: Change of MOT regs
Post by: McCabe-Thiele (Ted) on January 16, 2021, 04:00:56 PM
Our Jeep (54 plate) has aftermarket LED bulbs fitted to main & dip it passed last week - it's a local garage that I use they seem to adopt a common sense attitude. As long as the dip cut off is okay. Like all MoT test stations there is some variation on adherence to regulations. To check the bulbs on our Jeep WJ involves removing the complete headlamp as there is no rear access. MoT stations also say they cannot check certain suspensio & steering parts due to the body undertray!
Our Merc failed last year at MB main dealer on alleged mis-spaced number plate they the same dealership has passed this vehicle for the last 16 years on the same plates.
I actually think they were wrong so to get the test passed  I put some new alloy plates on the car for it to pass the difference was 4 mm on the spacing between B and the 4 and the end 3 letters. It did not spell a word and was not obviously mis-spaced.
As a mater of anecdotal interest when I was still a serving Police Officer we had notification from DVLA not to prosecute vehicles that had mis-spaced number plates as they were easier to remember by witnesses. That said DVLA still make a big deal about it if you have a cherished number being transferred.
Post by: Seamus on May 22, 2021, 08:32:17 AM
Correct Oddjob, Good old DVSA doing a u turn. Think the problem is that bulbs are specified accorning to their wattage, so LED's cannot be compliant unless someone pays for some sort of homologation. Expect to see all LED lights being acceptable in time, asssuming that they meet the pattern.
Must confess that we would probably pass most led setup's if the pattern was good enough. Unfortunately a lot of these have cheap leds fitted and the pattern is all over the place.
Some good quality ones about now, but are expensive.
