SOHC.co.uk Forums => CB750 => Topic started by: leadnavel on January 24, 2021, 12:18:58 PM
Title: Where are the front brake stop switch cables?
Post by: leadnavel on January 24, 2021, 12:18:58 PM
Can anyone tell me where I can find the cable connections for the stop switch for the front brake? In case other 750 variety's differ my stop switch is attached to three way joint. Is there a spur coming from the main wiring loom or does an extension come from the cluster of cables in the headlamp? Any assistance would be much appreciated.
Title: Re: Where are the front brake stop switch cables?
Post by: Phil Ward (RIP) on January 24, 2021, 02:39:15 PM
It comes from the main loom at around the headstock area - Green Yellow and Black I think from memory (check on the wiring diagram in Aladins cave)
Post by: leadnavel on January 24, 2021, 04:06:12 PM
Yes you are right philward Green Yellow and Black for the stop switch. I cannot see a spur from the main wiring loom with these colours!
Post by: Phil Ward (RIP) on January 24, 2021, 04:48:13 PM
Has the loom been re-bound and its been taped into the main loom? You could pick up the green yellow from the rear brake switch and a switched live black (to save unwrapping the tape on the main loom)
Post by: leadnavel on February 06, 2021, 02:54:45 PM
I unwound the insulation tape from around the loom but couldn't find any stop switch cables. The original plastic wire/loom casing was in pretty good nick after cleaning off all the insulation tape gum so happy with that.
Post by: leadnavel on February 06, 2021, 03:00:08 PM
 I had a look through my spare cables and found these bad boys! The elusive cables for the stop switch. The cable colours are correct, green/yellow & black and have just enough length in them to reach to the headlamp cluster for connection. Problem solved.
Post by: Andrew-S on February 06, 2021, 05:30:54 PM
If you've got just enough cable to reach the switch then make sure there's enough slack when the steering is on full lock without pulling out of the connectors.
Cheers,
Andrew
