Other Stuff => Tricks & Tips => Topic started by: Steris on February 04, 2021, 01:28:59 PM
Title: Pressure and Volt Gauge
Post by: Steris on February 04, 2021, 01:28:59 PM
Morning All..
I wanted a pressure gauge and a volt meter for my CB500K2. I couldn't find one available commercially so set about making one.
Quite pleased with the result, amazing what you can do when you're locked down and bored  :) :)
Andrew
Title: Re: Pressure and Volt Gauge
Post by: McCabe-Thiele (Ted) on February 04, 2021, 02:04:43 PM
That looks pretty neat nice combination of analogue & digital displays.
Post by: SteveD CB500K0 on February 04, 2021, 05:11:40 PM
What is a normal oil pressure?
Post by: K2-K6 on February 04, 2021, 05:31:20 PM
The relief breaches at 60psi I believe,  and they'd probably run 45psi and upwards when hot.
The oil light extinguishes much lower,  so really indicates if it's pumping and sufficient to not suspect a mechanical problem exists.
Post by: Steris on February 05, 2021, 08:55:43 AM
Hi OddJob
The display is 23mmx10mm. Off ebay £2.80
Hope that helps
Andrew
