SOHC.co.uk Forums => CB500/550 => Topic started by: captaindonutbikes on December 19, 2009, 07:48:26 AM
Title: swing arm bushes
Post by: captaindonutbikes on December 19, 2009, 07:48:26 AM
so Honda man does these bronze (  :D)jobbies for the 750 k swing arm. want some for my 550 k 3
anyone know where i can get some over here?
Title: Re: swing arm bushes
Post by: SteveD CB500K0 on December 19, 2009, 10:25:21 AM
He'll make you some if you ask him. He generally charges cost plus a $ for the site.
His real name is Mark Paris mgparis@concentric.net
Post by: captaindonutbikes on December 19, 2009, 02:21:18 PM
cheers steve
Post by: Bryanj on December 19, 2009, 06:10:01 PM
Remeber that the collar (or hollow pin) usually wears more than the bushes
Post by: captaindonutbikes on December 20, 2009, 07:32:22 PM
where can i get the rubber/metal suspension mounting bushes from?
Post by: Bryanj on December 21, 2009, 06:22:56 AM
Dave Silver mate
Post by: Spitfire on December 21, 2009, 08:25:19 AM
And they are fun to replace !
Den
Post by: Yoshi823 on January 11, 2010, 01:30:46 PM
I replaced the OEM plastic bushes with phosphur/bronze items on my 750F2, the wifes 550F2, a friend's 400F2 and a friends CBX1000Z with no trouble at all. I used a hacksaw to cut through the plastic ones, then pressed in the new ones after cleaning up the swing arm holes and zerk fitting. Just make sure that any shims inside the end caps go back in the same side as they come out.
