SOHC.co.uk Forums => CB500/550 => Topic started by: Phil Ward (RIP) on March 16, 2021, 01:24:45 PM
Title: 500 Start Up Issues
Post by: Phil Ward (RIP) on March 16, 2021, 01:24:45 PM
Another issue for your assistance! Having sorted oil pressure priming issue, plugs in and attempt to start (or not) - this is the issue:-
- Post getting oil pessure and having previously timed, etc, without plugs in, motor spins freely and spark at plugs
- Plugs in and motor does not turn but solenoid makes noise - thinks solenoid duff (new Motobatt fitted but not used since bought about 6 weeks ago) - changed solenoid for the one from my 750k2 - same (put back on 750 and tried starter as double check and works fine).
- Checked battery voltage and about 11.8 volts - charged overnight and 13.2 volts
- Fitted and pressed button and solenoid engaged and all lights went out - checked fuse and NOT blown - - - checked voltage on battery and ZERO - on to charger and no response at all (shows not connected on Optimiser) - battery shorted and blown?.
- Put jump leads from old car battery on bike battery leads and when pressing starter button, major sparks from live jump lead joint to bike leads
- took solinoid off and run + and - to input leads and switches with continuity
My initial thought was when battery at full charge, it was strong enough to engage solenoid and put a ground direct to battery due to permanent ground on starter cable (to solenoid) - but if this was the case, why didn't this issue happen when spinning motor without plugs in (solenoid engaged with lower battery voltage due to lower starter motor current draw) as motor ground lead still providing same poarity source.
I have continuity from ground on engine to starter lead - is this normal? (if not, why did motor work when solenoid engaged with motor spun with plugs out?)
- Trying to recover Motobatt via tandem battery method
Also got carbs dumping fuel but got my thoughts on that.
I'm taking a step back today as naffed off that it didn't start first time! (my previous projects started up straight away!) and before I strip the starter motor out and check (although it worked with plugs out!) would appreciate your views
Thanks in anticipation
Title: Re: 500 Start Up Issues
Post by: McCabe-Thiele (Ted) on March 16, 2021, 01:30:01 PM
Does it have a kick start - if it does will it start up manually so as to speak?
Post by: Phil Ward (RIP) on March 16, 2021, 01:32:06 PM
Doesn't want to start on the kick Ted (slight cough) - still need to cure this major issue as a priority
Post by: McCabe-Thiele (Ted) on March 16, 2021, 01:41:30 PM
If with no spark plugs fitted the starter motor spins the engine well but adding the plugs hence much more load ends up a fail I would at first suspect the battery. The clever chargers will usually identify an issue with the battery but a  modern digital drop tester is much better you input the battery specification and the little device does its magic - certainly my CTEK does indicate battery issues. In many ways what you are describing indicates that at lower current draw all is okay but at compression load it fails to turn to me that sounds like a duff battery - naturally you might suspect the starter motor especially if its of unknown condition or you have had it appart.
FWIW I would rule out the battery first. Next I would look at earth connections - engine to frame, battery to frame etc.
Post by: Nurse Julie on March 16, 2021, 01:56:09 PM
Having had a very similar experience on Millie, my 550 Mongrel, I would say a bad earth somewhere.
http://www.sohc.co.uk/index.php/topic,15937.msg133703.html#msg133703
Post by: Phil Ward (RIP) on March 16, 2021, 02:01:18 PM
It was the battery slightly low (hence not working with high current draw - plugs in and higher compression/load on the solenoid/battery.) The issue is the direct short when the solenoid switches - which points to what Ken suggests - but the baffling things is why this didn't happen when the motor spun without plugs in? (a short is a short?)
Post by: Phil Ward (RIP) on March 16, 2021, 02:20:00 PM
Julie, I have made new positive cable (crimp and solder) - I used the original earth strap but put new frame end terminal on but didn't change battery end as couldn't get a connector that would go through the right angle - will make a new complete cable up
Think I've done a continuity check on that coil area earth Ken (cleaned paint off) but will re-check
Should I have that permaent earth on the starter cable? (as to non electrician, the starter solenoid switching a live onto an earth doesn't make sense - unless it 'shunts' earth polarity to the one side of motor)
And why would above issues 'short' the battery to show zero?
No battery at mo as trying to recover - don't want to risk using my 750's Motobatt incase I nacker that one - so can't check motor temp - but zero's battery before motor able to spin (motor never spun under load)
Post by: K2-K6 on March 16, 2021, 02:42:05 PM
"Should I have that permaent earth on the starter cable? (as to non electrician, the starter solenoid switching a live onto an earth doesn't make sense - unless it 'shunts' earth polarity to the one side of motor)"
That doesn't seem right at all. With no battery at all connected you shouldn't be able to meter continuity via main starter lead positive to any earth.
Post by: K2-K6 on March 16, 2021, 02:44:54 PM
Forgot to add, as Ken suggested it looks like the starter motor is failing in some way. I'd look at that firstly, the car battery would probably have enough grunt and size to melt something if there's failure, that's in comparison to the bike battery.
Post by: K2-K6 on March 16, 2021, 02:51:00 PM
You could use the 750 as reference.
Meter for continuity down the positive starter lead across  to earth to give yourself reality check on numbers.
Post by: Phil Ward (RIP) on March 16, 2021, 02:52:57 PM
My thoughts too - when I fitted sprocket cover, the starter lead was inserted in the case grommet but from memory, on some of the Honda starter motors, the cable entry point can be suspect (short on the starter casing?). Got to take the better half for her covid jab this afternoon, so maybe tomorrow before I get the starter motor out
Post by: Phil Ward (RIP) on March 16, 2021, 03:16:23 PM
Why didn't I think of that! Just checked and I get same - ie, continuity - the live switching must 'shunt' the earth to the other side of the load (starter motor). This complicates it as why is the battery shorting itself out when I press starter button - solenoid engagement - bearing in mind that I've tried another solenoid? (its been on tandem charge - method to recover completely nacked battery - for 3 hours and still zero!)
Do I risk another shorted battery if I use the 750's battery!
Post by: K2-K6 on March 16, 2021, 03:19:58 PM
I wouldn't put a battery on until the starter motor is physically checked, risks doing the same.
IF it has taken the battery out it would be quite a chunky short.
Post by: McCabe-Thiele (Ted) on March 16, 2021, 05:16:26 PM
Are you using the type of charger that will charge a completely flat battery - pulse chage technology some call it? Do you mean Tandem or in Series? Charging in Parallel is unlikely to recover a very flat battery IMHO- to my knowledge only Smart Chargers or Battery Chargers over 40 years old are likely to succeed on a completely drained battery. Just my opinion.
Post by: Phil Ward (RIP) on March 16, 2021, 05:30:14 PM
I am grasping at straws Ted - I have been on Youtube and the parallel (or tandem) technique was suggested a few times - its an optimiser but have an old school charger as well (about 30 years old I guess) - which one do you suggest? May be a duff new battery and sparks from from when jump leads attached may be caused by inadequate contact between jump lead crocadile clip and bike leads (for starter motor current draw) - hence it went to zero as it was duff, not because of a short via solenoid (see previous post on a ground also showing on my fully working 750 starter lead.
Post by: Nurse Julie on March 16, 2021, 06:48:58 PM
I had my 1st Vaccination this morning Phil but I had to drive myself there 🙄🙄🙄🙄 Mrs Ward is a lucky lady having you Chauffeur her there 😁😁😁
Post by: Phil Ward (RIP) on March 18, 2021, 01:29:09 PM
Well got it sorted - and it was a simple fault. As suggested by Ken, starter cable pinched between case and sprocket cover (not were I thought and was careful when installing - near alternator case via grommet) but were alternator and starter lead come out (in the 'u' in the crankcase thats specifically for the cable exit). This is were it exited originally (when I stripped the bike) but as the alternator lead and starter cable are a real tight fit through this point, I've re-routed it under the engine bolt (above sprocket cover chain guard/plastic rear chain guard) and up the rear of the frame tube. Not sure that this is the correct route but its the most smooth/non shaiffing route.
I still read a ground on the lead but its from the ground on the other side of the motor windings (which is shunted to the other side of the motor windings when the solenoid applies a live) - as per the test on my 750 curcuit - as opposed to the 'shorting' ground which applied a direct ground to the live when switched.
M&P are replacing Motobatt too!
Post by: K2-K6 on March 18, 2021, 03:58:54 PM
Good news you got to the bottom of it,  and good job you didn't put the other battery on there! Lucky with the motobatt too  :)
Post by: McCabe-Thiele (Ted) on March 18, 2021, 05:43:16 PM
I see you found the cause of the problem  - still annoying when you find its something realtively basic but job well done.Ted
