SOHC.co.uk Forums => CB350/400 => Topic started by: Athame57 on May 01, 2021, 04:11:58 PM
Title: Float bowl adjustment
Post by: Athame57 on May 01, 2021, 04:11:58 PM
The float bowls in the carburetor third from left is sitting lower than the others and there is no springiness to them, what to do about it and what trouble could this be causing? I can't work out how to change anything. ::)
Title: Re: Float bowl adjustment
Post by: Nurse Julie on May 01, 2021, 04:25:33 PM
Your float height needs adjusting on the tang George. Follow this:-
Edit, is there actually a float valve under the tang, that float does look very, very low?
http://www.sohc.co.uk/index.php/topic,23233.0.html
Post by: Athame57 on May 01, 2021, 04:53:07 PM
Hi Julie, yes I took the thing of there is that thing underneath with the spring stud sticking out...I'll go pour over your link now.... ;)
Post by: Athame57 on May 02, 2021, 07:43:53 PM
I can’t see the tang, has it broken off?
You had me worried there, no it's still there, just that the flash has made it come up very light.
Post by: Athame57 on May 02, 2021, 07:46:10 PM
Before I go any further, I've been thinking how to best clean them while they are open, there is this film of dry dusty sort of blemishing. Any suggestions?
Post by: McCabe-Thiele (Ted) on May 03, 2021, 01:03:23 PM
I stripped mine right down then had my BiL Ultrasound clean the dismantled  parts.
