SOHC.co.uk Forums => CB500/550 => Topic started by: 1234pot on May 11, 2021, 11:10:25 AM
Title: 72 rear rim
Post by: 1234pot on May 11, 2021, 11:10:25 AM
Anyone know where I might find a sound original 18” D.I.D rear rim. I thought I’d cracked it. Totally refurbed the hub, including new brake lining. Had the existing rim rechromed. Only for the wheel builder to inform me it has hairline cracks and is useless. Gutted! Lesson learned there for sure.
Title: Re: 72 rear rim
Post by: Nurse Julie on May 11, 2021, 11:29:49 AM
What, the rim has cracks in it 🤔
Post by: 1234pot on May 11, 2021, 11:35:10 AM
Apparently Julie......Hairline. I haven’t inspected it myself but the wheel builder is adamant they’re dangerous! Old age.....I know the feeling!
Post by: Nurse Julie on May 11, 2021, 11:39:26 AM
Well, how bloody strange. I've never know steel wheels to get hairline cracks, bends and buckles but not cracks. That is most weird.
Post by: 1234pot on May 11, 2021, 11:55:52 AM
Once I have the rim back I’ll see if I can capture said cracks and post a pic or two
Post by: K2-K6 on May 11, 2021, 01:28:09 PM
I've seen them as the spoke nipple starts to pull the little "mole hill" form in towards the wheel centre and cracking up toward the hole such that you can't tension the wheel correctly.
Post by: 1234pot on May 11, 2021, 01:29:32 PM
Are you 100% sure he said the rim and not the hub eg brake lining. It's quite common to see the hub liner cracked and you may have misinterpreted what he was trying to convey.
Definitely the rim. The hubs 100% and it’s been relined, new bearings the lot. I’d waited an age to get it back from the Chromers. It’s doubly annoying because we checked them out to make sure they were true but didn’t register any cracks until they came back for fitting.
The whole idea of having a spare set of wheels has become a bit of a black hole!
Post by: Nurse Julie on May 11, 2021, 01:44:06 PM
Why do you need a spare set of wheels?
Post by: 1234pot on May 11, 2021, 01:49:08 PM
There’s no logic to it Julie. I inherited a set and it seemed like a good idea at the time....I probably need help.
I know I can get a repro but the originals have a different stamp so I’ll just have to keep an eye out.
Post by: Nurse Julie on May 11, 2021, 01:55:15 PM
You can't see the diamond stamp or any other stamp whilst your riding and nor can anyone else 😊😊😊😊 Safety over originality all the time, every time.
Post by: 1234pot on May 11, 2021, 02:05:59 PM
..... Always. I’m sure something will turn up at some point
Post by: Phil Ward (RIP) on May 11, 2021, 05:14:08 PM
I've got one (and front) that I replaced with new DID during my 500k2 rebuild - needs rechrome but chrome quite good with clean off'able surface rust on inner side. I was going to put them on ebay but PM me an offer to see what we can do. See attached pictures. Sorry, can't give it as selling whats good enough to re-coup some rebuild costs.
Post by: Phil Ward (RIP) on May 11, 2021, 05:20:58 PM
more pics
Post by: 1234pot on May 11, 2021, 06:23:59 PM
Many thanks Phil. Will do.
Post by: Laverda Dave on May 12, 2021, 08:41:48 AM
We used to crack test wheel sets on underground trains using a magnetic flux. An electric current was then applied providing a magnetic field around the wheel. The metal particles were then drawn into the cracks if any existed, indicating the wheel was cracked and only fit for scrap. I'm not sure if you can apply this method to your wheels and if the chrome layer will affect the result in any way but I have seen DIY type kits available.
Post by: 1234pot on May 12, 2021, 08:54:24 AM
The science is sound Dave so I don’t see why it wouldn’t work. In this instance I’m in the hands of a pretty experienced wheel builder.  I’m looking forward to seeing it for myself and will definitely post a pic.
Title: 72 rear rim
Post by: allankelly1 on May 12, 2021, 08:48:33 PM
Another crack test used is Magnaflux
It’s a liquid I believe that you apply that penetrates microscopic cracks then once the excess fluid is “washed off” you  then inspect under a UV lamp as the fluid  in the crack remains and glows under a uv inspection lamp?
