SOHC.co.uk Forums => Recommended Sources for Parts and Services => Topic started by: Andrew-S on June 04, 2021, 12:09:30 PM
Title: OEM Float Bowl Gaskets
Post by: Andrew-S on June 04, 2021, 12:09:30 PM
Anyone know where I can get original float bowl gaskets for my 750 K1 or know the part number as I cant find it in the Parts List?
DS do them in a gasket set kit at £25 per carb or repros at a few quid each, but I'm always wary of repro stuff or are these ok in use?
Thanks,
Andrew
Post by: JamesH on June 04, 2021, 12:44:05 PM
Andrew. The DSS repro carb bowl gaskets seem to be fibre-reinforced and don’t swell with ethanol fuel in my experience.:
https://www.davidsilverspares.co.uk/CB750K1-FOUR-1971/part_308031/
Alternatively, the DSS pattern carb kits (£9.95+vat) are keyster and are of a good OEM quality. Again these come with fibre reinforced bowl gaskets. :
 https://www.davidsilverspares.co.uk/CB750K1-FOUR-1971/part_228845/
I’d recommend both options.
Title: Re: OEM Float Bowl Gaskets
Post by: Andrew-S on June 04, 2021, 08:48:40 PM
Many thanks James.
